05 Suzuki Wiring Harness - Suzuki Forums: Suzuki Forum Site
Old 02-03-2005, 10:16 PM   #1 (permalink)
JohnR
Hello All!!
I found this awesome site and hoped that someone out there could help me! I am in need of a wiring harness to replace the current factory double dinn CD/radio to an aftermarket one and I CANNOT FIND A WIRING HARNESS anywhere for this car!!! At least for a 2005 model!! Can anyone help me??
My car is a 2005 SUZUKI FORENZA EX
Thanks so much!!
JohnR is offline   Reply With Quote Quick reply to this message
Old 02-19-2005, 05:33 PM   #2 (permalink)
ashark2
We are happy to help but do some looking on other posts this topic has been covered several times, the harness is a daewoo harness and din kit is the same. Daewoo Nubria. Spread the wealth what is the site?
ashark2 is offline   Reply With Quote Quick reply to this message
Old 06-06-2006, 11:56 AM   #3 (permalink)
redrockmica
Hey, just removed mine lastnight. This is pretty much getto style, but it worked nicely. Very, very carefully slide a very thin but stiff blade into the seam between the large center section and the rest of the dash. "It is held in place with simple snap tabs, no screws" Started on the left side, pried it out a little till i heard a gentle snap/pop, then went to the other side, and worked it there as well. The key is to be gentle, working it back and forth. With mine I didnt want to mess with the A/C controls, so I never actaully pried the whole cover off, maybe got it off 4 inches at the top. This is plenty. On either side of the deck are 2 philips/bolts, remove these, you can just get a screw driver in there. The radio as a L shaped bracket on either side, you need to pull the radio out a inch or two to access the 2 philips screws attaching these to the radio. once you get these off, the radio will simply slide out, through the silver bezel. I never had access to an adaptor for the harness, so I had to do the NASTY, and cut the wires. I cut them very close to the deck, but still left enough room to allow the radio to be re-installed in friends ride. There is a small wiring diagram on the top of the deck, but its a little sketchy, or I'm just daft at reading it. We re-installed the new deck, and wow!, its a JVC mp3/cd deck I got from best buy 2 years ago, now the car has amazing sound, through the stock speakers. big, BIG difference! When you hook up the new unit, the thick orange wire is actually your constant positive +"for clock memory", there are 2 yellow wires, one is a speaker wire the other is your main positive +. The speakers wires were trial an error, once you have power to the unit, its not hard to figure them out. There are also 2 black/white ground wires, I only used on and it works fine. All in all there were about 4 extra wires, I believe these were for other options available but not applicable to my unit. Hope this helps.
redrockmica is offline   Reply With Quote Quick reply to this message
Old 07-20-2006, 10:18 PM   #4 (permalink)
Loganator is an unknown quantity at this point
Default RE
hey guys check out ebay or Autotoys - car stereo, electronics and automotive accessories for a wiring harness for the forenza, or any other suzuki, they have it for them, I found one for about $7 including shipping...
Loganator is offline   Reply With Quote Quick reply to this message
Old 07-24-2006, 12:36 AM   #5 (permalink)
sp1d3rman87
redrockmica you're the man im getting ready to do the same thing and knowing that the center piece is seperate from the rest of the dash makse a huge difference in what i will have to do. By the way im installing an Alpine 9857 deck.
sp1d3rman87 is offline   Reply With Quote Quick reply to this message
