Amp and Sub install - Suzuki Forums: Suzuki Forum Site
Old 08-07-2010, 05:34 AM   #1 (permalink)
reddevil is on a distinguished road
Default Amp and Sub install
Please help me i have a sub and amp that i want to install into my swift sports with standard Head Unit tell me how and what i need to complete this job?
Also want to put mu ipod into the car too i know there is a clarion cable i can use ce net i think where can i get this from how much? Im in Adelaide Australia.
reddevil is offline   Reply With Quote Quick reply to this message
Old 07-09-2011, 08:40 AM   #2 (permalink)
nicknet is on a distinguished road
g'day,
I'm doing the same thing tomorrow morning - Sydney.
To use the stock head unit you'll need an amp with High Level Inputs or a high level input to rca converter (like so) and basically you run the speaker wire back to the amp, and then from the amp speaker output go back to the speakers. (if the stock head unit has RCA output somebody jump in here and save me a ton of trouble tomorrow but i'm pretty sure it won't).
The rest of the amplifier installation is the same as any other job, run your power lead with inline fuse from the Positive terminal through the firewall, down the side under the trim to wherever you are going to put your amp. There's plenty of vids online on how to do that.
The accessory wire is going to be interesting and hopefully I can find that quickly amongst all the other cables.
One thing to remember especially when using the high level input method is to run the power leads away from your speaker wiring, otherwise you'll hear lots interference or noise (alternator, engine, anything really).
Hopefully mine all goes well and I'll post some hints on how to route cabling and everything - I'm searching through the forums now to see if there are any pics already but if not I'll put some up.
I'm using Aux for my iphone - it works fine and my cradle is one the ones that sits in the vent so i have about a 5cm stereo cable so not too much loss of signal. Hopefully sounds good with a bit of power behind it.
nicknet is offline   Reply With Quote Quick reply to this message
Old 10-02-2012, 09:06 PM   #3 (permalink)
schwift is on a distinguished road
I figured i'd elaborate on this even though its an old thread it may help others.
I got a line out convertor off ebay for about $10, this one has two inputs but as a sub only requires one, i twisted them together and spliced and soldered them onto the wiring harness behind the center pillar trim.
The wires you want (for the rear left door speaker) are the light green, and light green with black stripe. - see wiring diagram in workshop manual.
(could only find red tape in my shed)
There was this nifty spot behine the trim that already had a hole, so i drilled another one lower and fixed in with a cable tie.
This amp was out of my previous car but fit perfectly here (note to check under the vehicle where you are screwing into, as mine was reasonably close to brake lines running to the back) put rubber caps on the screws if you are worried about the possibility of them rubbing on stuff they shouldnt.
For the remote wire, i took out the trim that surrounds the gear stick and took out the harness for the cig lighter, and spliced and soldered onto this. As this only gets power when the ACC is turned on, it seemed a good choice.
(i am looking to find and splice into the radio power wire as with the way i currently have it, when i hit the radio off button, the amp still has power through the ACC cig lighter, and this is causing interference of the sub with the radio off.
The negative is earthed onto the base of the handbrake adter testing with a multimeter and the power cable is run along the front of the ridge in front of the amp and out through a grommet in the firewall and into an inline fuse, then the battery
I then ran speaker cable to the boot down the centre of the floor and under the rear seat (you CAN run it down under the rear trims but IMO its a lot of work removing them when you can do it the above mentioned way and pop it out anywhere through the carpet.
I also kept it central incase i decide to install a carPC later and want to run my power cables down the drivers side.
Hope any of this helps.
schwift is offline   Reply With Quote Quick reply to this message
Old 05-14-2017, 03:49 AM   #4 (permalink)
bathurst1000 is on a distinguished road
where inside of the car dose the RED AMP wire come out once you poke it through the grommet on engine side , - thanks
bathurst1000 is offline   Reply With Quote Quick reply to this message
