Suzuki swift 2006 ABS and brake fault - Suzuki Forums: Suzuki Forum Site
Old 08-20-2016, 12:04 PM   #1 (permalink)
Courtneyhill is on a distinguished road
Default Suzuki swift 2006 ABS and brake fault
Hi I have a Suzuki swift 2006 3 door and recently I have been having problems with my brakes going extremely soft and needs the pedal to be pushed very low for any braking to happen. This only happens when my ABS kicks in and this happens an excessive amount of times. About a month ago I got my car serviced and bled the brakes and replaced the fluid but on the service the problem didn't happen so the mechanic didn't know what the problem was. I had since taken it back and he has re-bled the brakes again and it was working fine. The problem Has started happening again but it is intermittent and the brakes will go soft about 50% of the time that the ABS goes off. Does anybody know what is causing the excessive ABS and the low pedal fault?
Courtneyhill is offline   Reply With Quote Quick reply to this message
Old 01-11-2017, 03:58 AM   #2 (permalink)
cis202 is on a distinguished road
Default very similar here
When I push the brakes normally, nothing happens; only when I push harder and deeper car stops. I had it once in November 2016. Rear brakes were completely (pads + pumps) replaced and adjusted, brake fluid too and bleeding > pedal travel ok.
Now, since 7 Jan (last Saturday), I have the same problem again. I took off with the car and felt it immediately the first time I had to brake. No response until I push pedal deeper. When I push pedal several times after another, then pressure is ok but I have to do every time.
Did you get it solved?
cis202 is offline   Reply With Quote Quick reply to this message
Old 01-11-2017, 08:25 AM   #3 (permalink)
aquanaut20's Avatar
If you are not loosing fluid, first bleed and pressure test the MC, if no resolution, replace the MC.
...Philip
.... Philip
92 Ford Explorer, 450k
97 Ford Explorer, 400k
Old 01-11-2017, 12:42 PM   #4 (permalink)
What is the MC? (I am not a native english speaker)
Old 01-11-2017, 02:57 PM   #5 (permalink)
aquanaut20's Avatar
Master cylinder
.. Philip
.... Philip
Old 01-16-2017, 07:16 AM   #6 (permalink)
Dr Suzuki is on a distinguished road
does the brake pedal fall lower when you are trying to brake?
master cylinder or brake booster/vacuum or even slave cylinder problems will usually be consistent . most problems i have seen with the rs swift have been with the abs actuator itself , and usually inconsistant problems that dont even show up on a scanner.
Dr Suzuki is offline   Reply With Quote Quick reply to this message
Old 02-02-2017, 04:45 AM   #7 (permalink)
Default solved
bleeding did it, cost me 25 at the local Suzuki dealership. Tops
