Originally Posted by Max
You should be able to hunt down the relay "clicking" sound to locate it.  Then again I assume it's working, but then again I wonder if it's not since you are replacing the flasher.
From the FSM - an '05 XL-7 flasher relay should be in the underdash fuse panel area, one of the ones towards the top.
Also - the part number you provide does not appear to be a Suzuki number.
I'm showing the "Relay, Turn Signal & 4 Way" as p/n 38610-84F21
