Another keyless question
I have and XL-7 built in 3/02. While it was still under warranty the control module for the keyless entry was replaced with a programable unit and 2 new fobs. The origional had stopped working. It was fine until a month or so ago. I purchased another programable unit and installed it along with a new fob. I have followed the programming instructions several times with no luck in programming the new unit. I went as far as to disconnect the battery for a couple of minutes and tried it again. No luck.
Any thoughts or experiences with this that might help. I have read the other posted instructions on line here and they seem to match mine. Is there another part of the system that could be at issue. My power locks function properly with the button on the door. I can lock and unlock all doors with the key in the drivers door. Based on this it seems as though the system is functioning properly.
