» Sponsor Links
»Garage Storage and Cabinets
Old 01-04-2008, 11:34 AM   #11 (permalink)
MetalToyMaker's Avatar
MetalToyMaker is on a distinguished road
Thanks, appreciate the input BUT......that is the "axle gear ratio" or "final drive ratio" not the transmission gear ratio(s) nor the t-case ratio.
I'm trying to calculate rpm/torque for bigger tires. For that I need to know the hp/torque (roughly 180hp/180ft/lbs) of the motor, the transmission gear ratios, and the axle gear ratios (manual 4:30/1 or Auto 5:13/1). (^see the missing figures in the equasion?)
I need to get this figured to know weather or not I need to look for an auto or a manual to build.
I also want to know or verify the stock t-case ratio for calculating/guessing its 4wheel ability. This will tell me weather or not I just need to use the crawler gears from Calmini or if'n I can use the stock ones.
Am I in the right spot to ask these ?'s or should I try and find my answers somewhere other than Suzuki Forums?
Again, Thanks in advance for any help or a point in the direction of the information.
Mi ma sez ifn i can uze mi nife i dont needz no mo lernin.
MetalToyMaker is offline   Reply With Quote
Old 01-04-2008, 03:41 PM   #12 (permalink)
XL7Limited's Avatar
Im sorry metal. I misread it..
Old 01-04-2008, 05:46 PM   #13 (permalink)
netlos's Avatar
netlos is an unknown quantity at this point
Hey Metal,there is this one other forum i am on,a few guys there are really into mods,the activity is a lot lower than this forum,just takes a little while longer to get a response,you can try there heres the link http://www.zukiworld.com/forum/index.php?board=9.0
[/IMG]
netlos is offline   Reply With Quote
Old 01-09-2008, 04:18 PM   #14 (permalink)
XL7Limited's Avatar
I wrote that. I made a mistake by quoting you ..sorry!! Ill correct it..
to clairify- 03 was the last year for lever controlled 4wd and 4 speed auto trans. I wrote earlier that 02 was the last year..
Originally Posted by sattaker View Post
XL7Limited, I would appreciate you not editing my posts without putting a note saying that it is you who posted it. In my above post you wrote "oops your correct. 03 was the last year for the 4 speed and lever 4wd. My mistake.." as I did not write this.
Thank you
Sattaker
Old 01-10-2008, 10:00 AM   #15 (permalink)
sattaker is on a distinguished road
[quote=XL7Limited;113151]I wrote that. I made a mistake by quoting you ..sorry!! Ill correct it..
Thanks Limited. I don't mind being quoted, just don't want it to look like I said something I didn't.
sattaker is offline   Reply With Quote
Old 04-03-2008, 07:09 PM   #16 (permalink)
Default I may change gears....
What are the axle or final drive gear ratios for the 06 auto?
I may be able to pick one up in the next day or so if it don't get sold out from under me while I'm trying to find out the gear ratio.
Thanks Yaul!
Old 04-04-2008, 11:01 AM   #17 (permalink)
Originally Posted by XL7Limited View Post
yup 5.13 for the automatic is the stock gearing on the 01 and 02's. 03's with the 5 speed automatic has the 4.30 I believe.. But then you get the electronic 4wd with the 03's..
The transfer case is chain driven..
Can anyone confirm his belief?
I sure hope your right XL7Limited.
Thanks again for everyones help, advice, and time.
