Old 07-13-2007, 11:48 AM   #1 (permalink)
Caffeine_Charged's Avatar
Gallery: 6
Caffeine_Charged is on a distinguished road
Default Removal of Grille
Anyone have any tips on pulling it straight out? I've got pretty big hands and it's tough to get a grip on it. I'd hate for it to crack or to have one of those barbed plastic bolts snap. Any ideas for tools that would work well?
My friend took it off last time when I wasn't watching, but he also has quite smaller hands.
Caffeine_Charged is offline   Reply With Quote
Old 07-24-2007, 03:40 PM   #2 (permalink)
bmwpride's Avatar
bmwpride is on a distinguished road
just pull the grill out, it wont break.
bmwpride is offline   Reply With Quote
Old 10-24-2007, 01:55 PM   #3 (permalink)
mfred is on a distinguished road
it's attached in 4 places by plastic friction connectors if I remember correctly. I replaced my A/C compressor and had to pull the grille. The connectors are equally distributed starting outside edge, inside edge of headlights and opposite outside edge. You can try to pull a bit at a time at those 4 locations and work it off if you are afraid of cracking it. It's pretty tough though
mfred is offline   Reply With Quote
Old 12-08-2007, 11:48 AM   #4 (permalink)
Algonquin's Avatar
Algonquin is on a distinguished road
Positive attitude helps. If possible, remove the grille when it's moderately warm rather than first thing on a cold morning.
A Canadian perspective...
Algonquin is offline   Reply With Quote
Old 04-23-2008, 12:04 AM   #5 (permalink)
snamelc is on a distinguished road
Default remove grille
I use two screwdrivers bent at the tip in an "L" shape. Slide one above and one below the grille at each of the five lower attachment points and pull sharply. The fastener will pop out of its hole. Proceed across until all five have been released and the grille will slide out.
snamelc is offline   Reply With Quote
Old 04-23-2008, 11:26 PM   #6 (permalink)
I use plastic trim tools to pull it(Pry it) off the corners and center point.
Old 05-09-2008, 10:42 PM   #7 (permalink)
STORMCHASERXL-7
I just pulled mine off today to replace the clear forward marker light bulbs. I noticed that it has small cracks that have started to work there way around the plastic near the 2 outer plastic clips. I pulled the clips off, and plan to come up with a better way to attach the outer ends of the grill.
Regards,
Ivan
STORMCHASERXL-7 is offline   Reply With Quote
