Old 04-30-2007, 12:40 PM   #1 (permalink)
SASS is on a distinguished road
Default 2003 XL-7, A/C problems
Hello. First time post. I have a 2003 XL-7 with an A/C that sporadically alternates between blowing cold and hot air. When running the A/C for an extended period of time the air being discharged becomes hot. I then shut off the A/C and turn it back on and it returns to blowing cold air.
I can hear the compressor click on/off repatedly. It does not remain on for more than 20 - 30 secs and then clicks back off. has been to the dealer 3 times. They first filled up system with coolant and checked for leaks - found none. No report that they cannot duplicate the problem.
Has anyone experienced these problems? How have they been repaired.
SASS is offline   Reply With Quote
Old 05-04-2007, 12:03 AM   #2 (permalink)
Expansion valve usually solves this issue.
SuzukiDon is offline   Reply With Quote
Old 04-13-2008, 08:16 PM   #3 (permalink)
chardjones is on a distinguished road
What is an expansion valve and what does it do? How does it effect the AC? I'mn having the same problem and I've been told I need a new condensor.
chardjones is offline   Reply With Quote
Old 04-14-2008, 06:08 AM   #4 (permalink)
The expansion valve controls the release of the compressed gas to cause the cooling effect. It's fitted into the small radiator type device (I'm sure it's got a technical name ) under the dash that the inlet air fllows through to be cooled.
My old car did a similar thing because the expansion valve was icing up and stopping the gas flowing. It would cool for a few minutes and then blow hot air for ages, then a bit of cool air , then hot for ages.....
David.
2004 XL-7 Limited.
Old 04-29-2008, 06:02 PM   #5 (permalink)
ttocsmij is on a distinguished road
There was a factory service bulletin on this subject a while back. Check out TSB 0303273R (NHTSA #10001714). It was in re to an earlier year but it's probably related. Good luck.
ttocsmij is offline   Reply With Quote
