Old 07-01-2008, 10:35 AM   #1 (permalink)
biguy27 is on a distinguished road
Default transmission
how to i get to the transmission to put transmission fluid in and check the level if it has a dipstick
biguy27 is offline   Reply With Quote
Old 07-07-2008, 10:51 PM   #2 (permalink)
From under the car you need to pull the fill plug (8mm pipe plug socket) and check the level from there once warm. No dipstick.
Old 08-17-2008, 02:23 PM   #3 (permalink)
suzibyte is on a distinguished road
Re tranny oil fill plug. Just checking under my 1.8/ Esteem. Can't find anything obvious as fill port. 8mm socket is quite small. nothing matches. Can u elaborate?
I did find plug/bolt on side just under where shift levers attach (faces rear). Accessible from top, fits 9/16 socket (14mm?). Seems logical place although a bit small. It started turning easy enough but is not loose enough to finger turn so am a bit worried that i may be removing some mechanical bolt with disastrous results. Thoughts?
suzibyte is offline   Reply With Quote
Old 08-19-2008, 07:48 PM   #4 (permalink)
The esteem and the Veorona HAVE nothing in common. Esteem might just be a pan drop.
