Old 07-09-2007, 03:36 PM   #1 (permalink)
noelroadepica is on a distinguished road
Default no high beams 2004 epica
I am looking for some technical info on a 2004 epica that hasnt any high beams.Looking on the net i have found sites referring to the BCM .I am a tech so if I could get a wiring diagram for the BCM I might be able to troubleshoot it.The low beams/drls work ok and the pass feature doesnt work for the high beams either.I was looking for a relay to switch the high beams up but the only ones under the hood are for the headlights period doesnt show hi/low relay and the light doesnt come on in the dash for high beams.Any help would be appreciated.I have checked the lamps and the harness from the bulbs.
noelroadepica is offline   Reply With Quote
Old 07-19-2007, 01:37 PM   #2 (permalink)
TimMcCabe is on a distinguished road
Check the wiring harness located in the left front fender (remove the plastic liner, it comes out near the front door).
Take a look at the harness where it loops down, then back up, remove the plastic conduit and tape. Check the wires for a break, or where the insulation has become all rough and bubbled.
The headlight wire is pink if I remember correctly, it's most likely the cause..
Tim
TimMcCabe is offline   Reply With Quote
Old 07-19-2007, 09:02 PM   #3 (permalink)
Default I will check that
Thanks so much TIm I will have a look up there for the pink wire.I appreciate the help
