Old 11-05-2009, 01:27 PM   #1 (permalink)
myfantasy824 is on a distinguished road
Default need help with sx4 remote programming
not sx4 smartkey programming won't work
myfantasy824 is offline   Reply With Quote
Old 11-17-2009, 10:21 AM   #2 (permalink)
SDC
SDC's Avatar
SDC is on a distinguished road
Programming Transmitter Code for Keyless
Entry System (Other than Keyless Start Model)
S8RW019606015
NOTE
• Three transmitter codes can be registered.
• When a new transmitter code is registered,
the oldest one will be cleared.
If transmitter or BCM is replaced or additional
transmitter(s) is necessary, program transmitter code(s).
1) Confirm that all doors are closed and ignition key is
out of ignition key cylinder.
2) Open driver side door.
3) Turn ignition switch to ON position, and then drawn
ignition key from ignition key cylinder within 10
seconds after that.
4) Push and release driver side door switch 3
times by hand within 20 seconds after removing
ignition key from ignition key cylinder.
5) Turn ignition switch to ON position, and then drawn
seconds after that. All doors automatically lock and
unlock once.
With this, registration mode.
6) Push “UNLOCK” button on transmitter within
20 seconds after Step 5). All doors automatically lock
and unlock once.
With this, code registration is completed.
7) If an additional transmitter, needs to be programed
repeat the procedure of Step 1).
SDC is offline   Reply With Quote
