And... yes! The compressed air is what finally solved my problem!
If anyone's interested, I could post a picture of the exact location of the draining hose. You can even reach it without going under the car if your wheel is turned all the way to the left but then again, it wasn't the most comfortable position to slide in the air can.
I just started to have this same problem last night in my '08. Glad it wasn't anything major. That pic would be most helpful!
clearing the line alone wont solve the problem just mask it. if it clogged before it will clog again. you need the filter and the under cowl guard. just putting a filter in it just means your filter will back up without the guard.
also all your doing is pushing the crap back into the system by using compressed air or a coat hanger.
If you insist on doing something that suzuki will cover on your own then the best way... On the carpet under the blower is a small plastic nut, remove that and remove the passenger kick panel. Then remove the small plastic cover on the far forward of the passenger side center console (pull from the front, its one clip and then a slide at the back). Then pull your carpet back. theres a foam pad under there so fold the carpet after that foam so you dont break it. You can remove the whole drain plug this way and actually push the crap out of the car.
also dont let this go for to long because eventually it will back up enough to no only plug the drain but up into the control box. this causes alot of water into the blower and soaks the foam around the blower and loosens the glue.
sorry if that was long just wanted to be clear on how to fix this.
Wooah, pa_suzuki_tech, you reminded me that maybe I haven't really fixed my problem!
Well, til my next visit to the Suz dealership, here's the pic I promised (agreed, we can't see much but hey, I was leaning under the car holding the camera the best I could...). So there's the little bastard, this black curvy rubber tube on the left is the one you'll want to find.
I had my dealer look at this problem on my car and he says it's not covered under warranty, since I'm at 37,000 miles right now. Since there was a TSB issued, shouldn't I have been notified back then? It's going to be $180 for a kit to repair it. Thanks!
