Originally Posted by gio
Damn! I'm up to 1800 miles. What brand do you recommend on Oil. I gotta hit Jiffy Lube on Sunday then. Or will I get an indicator on my dash?
Are u saying i should change oil every 1500 miles?
You said:
As a personal note, the first oil change on both cars occurred @ 1500 miles. The oil used was a 5/40 Synthetic. Synthetic oil provides superior lubrication compared to regular oil, thus less friction which equals to smother operation, better fuel economy/acceleration.
It appears you have misinterpreted my post. I wrote that the first oil change occurred at 1500 miles. This is the oil which carries all the filings/shavings during the break in period. Contrary to almost every manufacturers recommendations I do not want the factory oil in the crankcase for any extended amount of time. 1500 to 2500 miles is enough for the oil to carry the aforementioned shavings. Then out it goes. I have owned many new cars over the years and with every “first” oil change I always send a sample to the lab for analysis. No matter which motor I’ve had the analysis always comes back with an ugly report. “Change oil immediately”, “heavy metal content”, etc, etc, etc…
As for your response, I do my own oil changes, I do not go to Jiffy lube.
Never have never will! When it comes to my motors only “top shelf” nothing else will do!
I use only synthetic oil. Either Castrol 10/60, Pentosin 05/40 or Rotella 5/40, and always a Bosch filter with an anti drain valve. Unless I happen to own a vehicle with a paper oil filter, then it’s a Mann or Hengst.
As for indicator(s) on your dash, I have no idea what you are referring to.
As for your oil change intervals, do as you wish. Personally, the first LOF is at 1000-1500 miles. Then every 4000 miles thereafter.
