» Sponsor Links
»Garage Storage and Cabinets
Old 03-29-2008, 11:43 AM   #1 (permalink)
jserrent is on a distinguished road
Question Center armrest....???
Has anyone here installed the optional center armrest ? I know it fits into the little square slot at the end of the console trim, but how does it attach firmly from there ?? Any drilling? Does it come with necessary hardware ??
jserrent is offline   Reply With Quote
Old 03-30-2008, 10:07 PM   #2 (permalink)
rovert97's Avatar
rovert97 is on a distinguished road
the OEM armrest attahces with glue. then they found out there was a problem with it breaking loose, so they redesigned it, and now have a different model # for the armrest. im not sure if they glue and screw it now tho. i bought the non OEM armrest off ebay and installed it myself with just the 4 supplied screws. it may not look perfectly OEM like the, well, OEM armrest, but i like it better due to the fact that it has a retractable cup holder for the rear passanger.
2007 Black Onxy Pearl Auto SX4 w/Conv. Package
Mods: RRM Intake Kit, PIAA Driving Lights, Pinstripes, Mud flaps, armrest, Silverstar headlights, Yokohama Rubber, and a whole lot of mud!
SX4CLUB.COM
My CarDomain Page
rovert97 is offline   Reply With Quote
Old 03-31-2008, 10:36 AM   #3 (permalink)
King Tuskis's Avatar
King Tuskis is on a distinguished road
There is also this one, which folds up. I think someone may have a thread on this at the sx4club.
armrest-autoaccessories.com - SUZUKI SX4 SX 4 armrest accoudoir bracciolo SWIFT
It takes hundreds of nuts to hold a car together, but it takes only one of them to scatter it all over the highway.
- Evan Esar
King Tuskis is offline   Reply With Quote
Old 05-30-2008, 07:37 AM   #4 (permalink)
socarboy99 is on a distinguished road
I installed a OEM issue armrest in my 08 SX4 sedan a few months ago. It cost around
$130.00 at the dealer.
Step one: carefully pry off the top parts of the consule from the rear part (where single
square cup holder is) tilting it towards to gear shifter.
Step two: (applies to AWD models only) unplug drive selector switch plug for
2WD/AWD selector switch
Step three: pry off the lower consule extensions at the front of the lower part
of the consule on each side.
Step four: remove all of the screws for the lower part of the consule that are
now exposed.
Step five: remove consule assy from vehicle. It will simply lift out once all the
screws are removed from step four.
Step six: remove and discard original metal bracket bolted to floor and replace
it with the different bracket furnished in the armrest kit.
Step seven: take removed consule to a work table, look at the directions to find
measure mark and drill 4 holes in consule. There are two holes to be drilled in the
back of the consule and one hole on each side. Drill first with a 1/8" bit, then enlarge
holes to 3/16" and finally upsize each hole to 5/16".
Step eight: reinstall lower part of consule in to vehicle. Reinstall all factory bolts, and
extension panels removed in step three.
Step nine: snap back on the top part of the consule.
Step ten: fasten the armrest to the new floor bracket, with kit supplied screws, that was put in in step six.
Step eleven: Pop on decorative black caps supplied in kit over four screw holes that
bolt armrest to floor bracket.
You're done!!!
socarboy99 is offline   Reply With Quote
Old 06-15-2008, 12:21 PM   #5 (permalink)
Jaydaddy is on a distinguished road
Does anyone know if this will work on an SX4 Sedan with a 5-speed? Would it interfere with shifting, or is there sufficient clearance?
Jaydaddy is offline   Reply With Quote
Old 06-15-2008, 02:15 PM   #6 (permalink)
This kit works on either an automatic or 5-speed vehicle Crossover or Sedan
Old 06-26-2008, 03:08 PM   #7 (permalink)
notebook_walter is on a distinguished road
Default My Armrest
I own this one:
PASSGENAUE ARMLEHNE Mittelarmlehne für SUZUKI SX 4 SX4 bei eBay.de: Innenausstattung (endet 27.06.08 19:42:13 MESZ)
br
Walter
notebook_walter is offline   Reply With Quote
