Thanx Suzuki Don. I knew that it is drive by wire. I had schematics, I just thought they were wrong, they weren't. Suzuki shows the ECM connectors numbered 1-15 and 16-31 and so on, but in actuality, it is backwards. I have never seen anything like it. I informed Suzuki about it. You are correct about the SX4.. Same ECM and clock spring assembly but no wiring from the clock spring assembly to the ECM. Switch wiring is not present and brake and clutch inputs are not present either. We have a working prototype and we should be in full production swing in a few weeks. Also the non cruise models have a differrent horn pad / air bag so you can't just add switches and wiring. Thanx for the reply
