Old 09-23-2009, 04:01 PM   #1 (permalink)
garysco's Avatar
garysco is on a distinguished road
Default More power after I did this
I picked up a 94 Metro with 150,000 miles in Fresno Cal. in good shape. It ran OK, but had low compression (150 psi) & gutless. The seller said it had been sitting for about 6mos, so new gas & oil change, but little improvement. Added a small can of "Restore" to the oil. Now I get about 40mpg & pretty good power. Anyone know why such a big improvement? I will check compression & re-post.
garysco is offline   Reply With Quote
Old 09-25-2009, 08:20 PM   #2 (permalink)
Johnny Mullet's Avatar
It is possible the Restore cleaned carbon deposits from the valves that were sticking from buildup. Check your ignition timing and advanve it to 8-10 degrees BTDC to help prevent carbon buildup.
If the Restore ends up a temporary fix, you might need to replace burnt exhaust valves.
Old 10-05-2009, 03:56 PM   #3 (permalink)
Holsetmetro's Avatar
Holsetmetro is on a distinguished road
your injector probably had a ton of carbon built up around them and the combustion chamber.. It s not necessarily a burnt exhaust valves. The ignition timing is a good idea, to try.
Later,
John
Holsetmetro is offline   Reply With Quote
Old 10-05-2009, 10:39 PM   #4 (permalink)
Minimum compression on a Suzuki G10 or G13 is 156 PSI
Old 10-13-2009, 04:04 AM   #5 (permalink)
sophia.sam is on a distinguished road
I am also facing the same problem. Shall i go for the same and how much it will cost? Its a second hand car. Thanks in advance.
Sophia Suzuki Performance Chip
sophia.sam is offline   Reply With Quote
