Old 06-24-2009, 01:10 AM   #1 (permalink)
iseestars is on a distinguished road
Default 1997 Swift DTC trouble
I have a 97 Swift 1.3L Auto. I have a code p1250- EFE Heater circuit. Can anyone tell me what to test, or how to diagnose the fault.. I have a scan tool to read, and erase the codes. I have a Chilton brand manual- and it has NO info on diagnosing. So, if anyone has info, or a link to a SHOP MANUAL, that they can share with me thats would be most appreciated. thank-you
iseestars is offline   Reply With Quote
Old 06-24-2009, 10:43 AM   #2 (permalink)
WIRING DIAGRAM
CIRCUIT DESCRIPTION
In this system, air/fuel mixture to be drawn into the engine combustion chamber is warmed up to improve the burning efficiency while engine warming up. Located between the throttle body and the intake manifold, EFE heater is turned ON and OFF by its relay which ECM controls. EFE heater is turned ON while engine warming up (when coolant temp. is low and engine speed is higher than specified idle speed) and it warms air/fuel mixture which passes through it and as a result, fuel is atomized better.
DETECTING CONDITION AND POSSIBLE CAUSE
DTC CONFIRMATION PROCEDURE
Turn ignition switch OFF.
Clear DTC with ignition switch ON.
Check vehicle and environmental condition for:
indication of fuel level meter in combination meter: 1/4 or more
Altitude (barometric pressure): 24OOm, 8OOOft or less (560 mmHg, 75 kPa or more)
Ambient temp: -10°C, 14°F or higher
Intake air temp: 50°C, 122°F or lower
Start cool engine and warm it up to normal operating temperature
Check pending DTC in "ON BOARD TEST' or "PENDING DTC" mode and DTC in "DTC" mode.
2008 suzuki SX4 sport sedan 5spd FWD
2006 suzuki boulevard C50 SE
lumpylarry is online now   Reply With Quote
Old 06-27-2009, 09:04 PM   #3 (permalink)
Update, I've been draggin my feet on this, but here is where I am now. The 30amp PTC fuse was open. I changed it, and in less than a minute, at idle, it popped. I unplugged the heater at the manifold, and so far it has not blown the fuse- it does reset the code P1250. I have yet to read the heater impedence- although I am unsure what the value should be. Anyone wanna measure theirs and tell me what you get? Thanks!!
Old 06-27-2009, 09:05 PM   #4 (permalink)
Default thank you!!
Many Thanks to LL for your response!!
Old 07-10-2009, 05:37 AM   #5 (permalink)
Brian124 is on a distinguished road
Originally Posted by lumpylarry View Post
WIRING DIAGRAM
CIRCUIT DESCRIPTION
Thanks for the info.I have 2004 Swift.This info will help me too.
I Got new BBS wheels for my Car.
Brian124 is offline   Reply With Quote
Old 07-18-2009, 03:42 PM   #6 (permalink)
CULTUSTOM is on a distinguished road
I have the same problem. Unplugging the EFE heater connector solves the fuse-blowing issue but the P1250 DTC will re-appear as soon as the engine temp is warm, when the EFE-off signal voltage is unable to be measured. My EFE heater falls in the middle of specified normal electrical resistance (it is 1.6 ohms at 68 degrees F), but I suspect the problem is that the EFE heater is shorted to ground through a faulty TB gasket; this would explain the PTC fuse blowing as soon as you start the engine. I am ordering a new EFE upper and lower gasket, which are about $10, a lot cheaper than assuming a need to replace the $300 EFE heater.
CULTUSTOM is offline   Reply With Quote
Old 07-18-2009, 05:09 PM   #7 (permalink)
Thumbs up I tricked the PCM!! he he
Check this out. On the wiring digram you can see that output side of the relay feeds the heater, and the PCM. I am guessing its looking for current flow, or a load. As I mentioned earlier I have unplugged the heater pigtail and the fuse no longer opens. So, I put a 194 light bulb ( only cause thats what I have a socket and wires for) into the now vacant heater pigtail. And PRESTO!! the service light went out!! I have cleared the code and am road testing now.
