I had the same problem with my Geo. I found a loose wire at the fuse box. But until I found that and fixed it I attached a wire to the plug in the back of the headlight and when driving at night hooked that wire to ground on the body. The headlights are hot all of the time. You can unplug the headlight and slip a wire into the low beam when you replug the head light. May not be a recommened method, but it worked until I found the problem.
