Let me elaborate on the A/C Vacuum Switch Valve.. That screw controls the idle speed of the a/c... Here is how you adjust it according to the 1991 copyright haynes manual:
1. With the engine operating at normal temp, connect a tachometer and switch the a/c ON.
2. Install the spare fuse into the diagnosis switch terminal.
3. Check and adjust the idle speed by adjusting the A/C VSV idle screw to the proper spec: automatic transaxle 850 + or - 50 rpm, manual transaxle 900 + or - 50 rpm.
4. Remove fuse
5. Adjust the idle speed to the rpm spec (the screw is into the throttle body, the idle speed official chart is on a sticker on the bottom of the hood)
1991 Geo Metro 5spd
1991 Ford Festiva GL 5spd
