hi there..i have a 94 metro 3 cyl 5 speed. i ran a diagnostic on my car that had the check engine light on. the system reported a code 42. when i looked it up in the book though it is for a crank angle sensor/camshaft positioning sensor..which in my case is actually the pick up coil inside the distributor..refering to your problem, im not sure if that is the same as the crankshaft position sensor, which is near the oil pan, unless crank angle sensor is another name for the crankshaft position sensor. so confusing
i would be grateful if someone had any information on this problem that theyd be willing to share, like how to correct it if theyve experienced something similar or just have the solution. the book says to check the connector of the sensor and to check for a circuit. it also says to check for the correct air gap between the distributor and the pick up coil(camshaft positioning sensor) i got the feeler gauge and im ready to go in. the plug looks like it was pretty tightly squeezed in there but hopefully it will come out with ease this weekend, or perhaps i have an incorrect gap and correcting it will solve the problem. i did notice a few drops of apparently fresh oil inside the distributor. i hope that isnt an indication of ANOTHER problem. thanks for any help you guys can give. you guys are great..i have read your posts on this site before and im sure a lot of people are grateful to you for saving them time, money and headaches. kudos!
