It's finally back together and so far so good.
Started on the first few revs, no smoke visible, (other than residual assembly oil for 15 seconds) and no burned oil smell at highway speed.
3 exhaust valves, rod bearings, all gaskets, new rings, valve seals, 5w-30, deglazed cylinder walls with ball hone. (they were very uniform but about .004 oversized)
Set timing at about 6btdc.
Next to adjust idle stop and screw in TB for best overall idle as they both have been screwed with by us and the previous owner.
this was a good day. 18 days for us to have time, weather, and help permitting this whole deal.
How do you even know if EGR is opening the valve what with the other 2 devices in the mix? I'm tempted to run a T in the input to the actual EGR valve and monitor vaccum there at highway speed. If it will open with applied suction while off, I guess vaccum at speed would mean the other parts are working??
just for fun:
purchase price $500.00
sales tax $ 6.00
title, plate $ 74.50
catalytic converter, head pipe $111.45
middle pipe $ 61.16
exhaust donut and gasket $ 6.13
muffler $ 38.02
dist cap $ 9.81
rotor $ 7.23
alternator belt $ 10.50
spark plugs $ 3.90
rod bearings $ 18.78
ring kit $ 79.79
head bolts $ 20.58
egr gasket $ .58
intake gasket $ 5.85
exhaust gasket $17.94
red rtv sealant $ 4.89
pcv valve $ 5.33
valve seals $ 25.00
lappimg compound $ 3.37
lapping suction tool $ 5.30
timing belt $ 14.87
tires, alignment $243.35
PA inspection $ 22.10
head gasket $ 24.95
valve cover grommets $ 8.00
cam seal $ 2.41
oil $ 9.50
tax(parts, align, inspection) $ 49.99
total $1389.11
now to start saving on gas.....
Renix is just another name for Succubus
