Try to determine the color of the smoke. At start up a puff of white smoke is usually antifreeze-blue smoke oil. A leaky head gasket or cracked head can allow some coolant to leak into the combustion chamber at rest. Similarly, marginal valve guides or worn valve seals allow some oil to leak in. Sometimes the Snake Oil remedies can temporarily revive stiff seals.
Originally Posted by crxcte
It does not smoke when running only at startup.
Looked for the PVC valve but not sure where it located.
Note that "PVC" means PolyVinylChloride, what you're looking for is the PCV valve, which stands for PositiveCrankcaseVentilation. Sorry, don't know where they are on 1.3 motor.
If you had "too much" oil it would tend to blow out while running & you'd have seen the level drop.
