Old 06-11-2008, 01:09 PM   #1 (permalink)
dgowens3 is on a distinguished road
Default Front Wheel Bearing in 96 Geo metro
I'm just curious about what I need to replace or buy in order to replace a front wheel bearing in a 1996 Geo Metro...
dgowens3 is offline   Reply With Quote
Old 06-11-2008, 10:30 PM   #2 (permalink)
Johnny Mullet's Avatar
It's not a hub assy, but inner and outer bearings on some and one bearing on others (forget which is which) and does not seem to be that bad of a job if you can get the bearings out of the hub without a press.
Old 06-12-2008, 12:49 PM   #3 (permalink)
thanks for the advice
Old 06-12-2008, 07:25 PM   #4 (permalink)
hotrodfeguy is on a distinguished road
Fairly easy just basic hand tools. Did inner and outers on mine this spring. Do yourself a favor and buy the double sealed bearings. this holds the grease in the bearing. they cost about $5 more but well worth it.
hotrodfeguy is offline   Reply With Quote
Old 06-14-2008, 04:25 PM   #5 (permalink)
Default another question
when you removed the disc brake assembly did it have 4 mounting bolts? because on this vehicle there are only 2 screws and i'm wondering if that is really holding me back don't know how to go about getting the screws off since they're on there really good
Old 06-14-2008, 05:27 PM   #6 (permalink)
Use an "Impact Screwdriver" with a good, sharp phillips bit. Then strike it with a hammer to get it loose. Worse case, you gotta chisel them out or drill them out. They are not needed after putting back together.
Old 06-15-2008, 09:50 PM   #7 (permalink)
akcapmetro's Avatar
akcapmetro is on a distinguished road
Just out of curiousity, how do you know to replace the bearings... vs. say, the CV joints, etc.?
akcapmetro is offline   Reply With Quote
Old 06-16-2008, 08:08 AM   #8 (permalink)
Noise mostly, To check the joints you can grab the shaft and see if they(joints)are loose. Sloopy joints will cause a vibration. Sometimes felt in the steering wheel. The wheel bearing just growls and makes noise up front.
Old 06-16-2008, 03:29 PM   #9 (permalink)
anyone have a "ghetto" way of getting the hub back on? i'm trying to figure this one out without buying more tools.. kinda short on cash with the price of gas atm...
Old 06-16-2008, 08:36 PM   #10 (permalink)
I just used a old socket I didnt care about :0) hammer good
