If i's "gas" fumes (not "exhaust") then you likely have a line off your Vacuum Canister which is near firewall and could be drawn in fresh air vents (other possibilities: (1)Vacuum Canister Check Valve is stuck open and a drawing liquid instead of just vapour;(2) if you have Carb ...mixture could be too rich (if it's this latter don't adjust anything until you've put in new Air Filter, Fuel Filter, and PVC Valve ...sensors will then have a better chance of correcting the air/fuel mix)
