» Sponsor Links
»Garage Storage and Cabinets
Old 04-27-2008, 11:36 PM   #1 (permalink)
Johnny Mullet's Avatar
Default 1.0L head rebuild guide with pics
Hello! I am a new member and a new owner of a 1998 Chevy Metro 1.0L with a 5 speed. I got this car dirt cheap and decided to fix the dead cylinder due to compression loss. Here is my guide.................
The most common issue with these 3 Cylinder engines for a dead cylinder is burnt exhaust valves from either timing or clogged EGR ports.
This guide can be used for all 3 Cylinder Suzuki engines.
Get the car in a suitable work area.
Set engine so Cyl #1 is at top dead center (TDC).
Disconnect battery.
Drain the oil and coolant. (17mm drain plug)
Remove upper rad hose from engine side. (squeeze clamp)
Remove throttle cable and all attached vacuum lines. (12MM locknut & squeeze clamps)
Mark plugs and wires and remove wires, cap and rotor. (8MM bolts)
Mark distributor and remove. (T40 or 12MM)
Remove the air cleaner housing and tube. (10MM bolt and nut)
Loosen the alternator bolts (one on top and 2 below) and remove belt. (12MM bolts)
Remove the water pump pulley. (10MM bolts)
Remove the crank pulley. (5 8mm bolts - don't remove center bolt)
Remove timing belt cover. (8 10MM bolts and loom holders)
Check and correct timing marks and note rotation.
Loosen tensioner and remove belt and mark belt rotation if re-using it. (12MM bolt)
Inspect water pump and replace if questionable (wanna do this again?)
Remove exhaust manifold bolts and use heat if tight & pull away from head. (10MM bolts and nuts)
Remove the 4 valve cover nuts and strike the seals off. (10 MM)
Remove the head bolts with a breaker bar from outside in. (8 10MM 12 point bolts)
Get a buddy to lift up head & intake assy and remove vacuum lines, grounds, fuel lines, etc)
Look on cylinder head for the small oil check valve and don't loose it!
Place head in a clean work area with lots of room to work.
Put rags in cylinder holes and clean mating surface on head, pistons & exhaust manifold.
Clean head surface and clean out the EGR port.
Remove EGR valve and clean all ports.
Remove the camshaft bolts and cam and remove the gear and replace seal. (6 10MM bolts/studs - 17MM cam bolt)
Remove the lifters put in order.
Use a valve spring compressor with adapter and remove the valves (keep parts ordered and use your buddy)
Clean surfaces and lap in all the valves (intake & exhaust) with lapping compound and re-install.
Re-install lifters and camshaft. (use torque specs from a manual)
Double check all of your work and gasket mating surfaces.
Remove intake from head and replace gasket. (optional)
Get your buddy to help you re-install the head and double check all connections!
Torque all 8 head bolts to specs and order with info from manual.
Install a new timing belt (or used one like a dummy) and check timing marks.
Re-assemble the same way you took it apart and please double check vacuum lines since there is a lot of them.
Clear all DTC if you forgot to disconnect battery.
Fill oil and coolant and fire it up!
Now you may have to set the timing, so reference your manual!
Let the car get to operating temperature and check for leaks and burp the coolant.
Test drive and watch the coolant temp since an air pocket may occur.
Now that you are a certified Suzuki mechanic, get a job!
I hope you enjoyed my guide!
Visit the all new GeoMetroForum.com
Old 04-28-2008, 12:43 AM   #2 (permalink)
hvdragon's Avatar
Gallery: 8
hvdragon is on a distinguished road
excellent! 10x.
http://swift.hit.bg
hvdragon is offline   Reply With Quote
Old 07-26-2008, 06:09 PM   #3 (permalink)
jode is on a distinguished road
Wish I would have known about the fact that you can remove the crank pulley without removing the crank bolt before I pulled it this morning (Doh!) Great tip!
I also just pulled my head today and now you have me in complete fear due to your comment to: "Look on cylinder head for the small oil check valve and don't lose it!"
Can you provide any more info on this? I never saw it and don't know where to look
jode is offline   Reply With Quote
Old 07-26-2008, 08:12 PM   #4 (permalink)
