I bought this car used,( for the politicaly correct <pre-owned>) when the gas prices went up.in the summer months i've had no problems,when it got cold,there was a problem with it starting.it has a mind of it's own.I have changed the plugs.distributer cap,rotor button, fuel filter.still will not start in the cold.
Try to pull the codes up on your computer. you can do this by, putting a spare fuse into diagnostic fuse port on your fuse block. Insert your key into your ignition and turn it to the on position, no need to start the car. Next, count the times that your check engine light flashes. Example: if it flashes three times and then once, that would be a code 32. You will have to thry an auto parts store or your local library to look up the codes and what it means. Good luck.
I have here in Brazil, and am initiating the knowledge for this type of car. it would like to know if voce has the repair manual, so that it can deepen me the problems of this car.
