» Sponsor Links
»Garage Storage and Cabinets
Old 12-22-2005, 11:04 PM   #1 (permalink)
Geof
I have a suzuki swift 1995. It never want to start when I turn the key I only heard a little hum (noise). I tried to boost it and I checked all fuses. The inside lamp work properly.
What it can be the problem?
Geof is offline   Reply With Quote
Old 12-27-2005, 06:39 AM   #2 (permalink)
stevo
The little him could be just the fuel pump if it goes off after a few seconds, if there is no click when you turn to the start position I'd first check you have a good earth for the starter motor and failing that I'd suspect the solenoid on the starter motor. You have made absolutely sure the battery is good?
stevo is offline   Reply With Quote
Old 12-28-2005, 03:41 PM   #3 (permalink)
old peter's Avatar
old peter
could be fuel pump herd they have called back 2005 swift for a fault on pump
old peter is offline   Reply With Quote
Old 12-28-2005, 05:38 PM   #4 (permalink)
Geof
I found the problem. A little wire on the start was cut. This wire is between the solenoid and the sarter motor. It is a classical problem
Old 01-01-2006, 06:43 AM   #5 (permalink)
old peter's Avatar
old peter
very good that you found the problem
