clunking noise - Suzuki Forums: Suzuki Forum Site
Old 12-31-2012, 01:54 PM   #1 (permalink)
blaze10 is on a distinguished road
Default clunking noise
When I engage 4wd or disengage it back into 2wd I drive about 75 feet an ill hear a clunk what could it be my transfer case its mostly when I take it back into 2wd an yes I do this when the vehicle is completly still. . If I go from 4high to 4low it does not make that noise.. what could it be. Im sorry for the annoying questions im young an very ignorant when it comes to these trackers
blaze10 is offline   Reply With Quote Quick reply to this message
Old 01-01-2013, 05:17 AM   #2 (permalink)
Section Moderator
Do you ever drive the car in 4wd on dry surfaces? If so, you shouldn't - this is part time 4wd, and must only be driven on surfaces where the front wheels have the ability to slip. Have you ever checked or replaced the oil in the transfer case? If not, you should. Do you have auto or manual hubs? If they are manual, have you ever taken them off and serviced/lubricated them? Sadly, not really possible to do with auto hubs. From your post, it sounds like you have the auto hubs??
'61 NSU Quickly - 150mpg
Old 01-01-2013, 05:23 AM   #3 (permalink)
No they are manuel locking hubs I just bought this an no I do not drive on dry surfaces.. this is off road an atm our mountain trails are covered in mud. I do know I think I need new locking hubs because I cant lock them by hand I need plyers to turn them.. an the driver side one acts like the plastic piece is about to fall out. .. how do you check the fluid in the transfer case ? Thanks for the reply
Old 01-01-2013, 05:24 AM   #4 (permalink)
Not mud snow lol*
Old 01-01-2013, 06:04 AM   #5 (permalink)
Section Moderator
Put the specs of your car into your signature, so we know what you're driving. If it is an earlier model Trackick, then you have the Aisin manual hubs on your car. These can and should be serviced yearly.
Manual Hub Clutch Assembly
As a test, you can completely remove the entire hub from the car (the 6 screws that are furthest away from you on each hub) and drive. See if you still get the clunk when you put the transfer case into 4wd. If not, then you know the hubs are the problem. Aisin hubs are easily serviceable.
In any event, you should check your transfer (and tranny) fluid, as well. Are you manual or auto tranny?? The transfer case has a filler and drain plug. BEFORE you remove the drain plug, make sure you can get the filler plug off the car. Transfer case fluid (GL-4) should be filled to the filler plug, with the car level. If you have never changed these fluids (tranny and transfer case) it is a good idea to do so, even if you find that this is not your clunking problem. Might want to consider changing the oil in the differentials, as well (GL-5)
Old 01-01-2013, 11:34 AM   #6 (permalink)
Ok ill put ny specs in but its 1995 geo tracker auto tranny 4x4:1.6 16valve. Two door soft top
Old 01-01-2013, 12:49 PM   #7 (permalink)
razor02097's Avatar
Don't replace the hubs... Clean and lube them. The factory hubs on these vehicles are great and only stick when they aren't maintained.
Question: When you put the transfer case in 4hi or 2wd are you in drive? If so try shifting to neutral before moving the Tcase lever and see if it clunks or not.
razor02097 is offline   Reply With Quote Quick reply to this message
Old 01-01-2013, 02:05 PM   #8 (permalink)
Ill test that out razor. An I have a questiom that black plastic piece on these hubs the one feels like its gonna pop off.. what do I do to fix that
This is my tracker
Old 01-01-2013, 03:44 PM   #9 (permalink)
I tried doing it in neutral an once again when I engaged it into 4wd it ran fine as soon as I took it out while in neutral it clunked after 75 feet
Old 01-02-2013, 04:55 AM   #10 (permalink)
How do you clean an oil our hubs ?
