Cambelt timing marks - Suzuki Forums: Suzuki Forum Site
Old 12-10-2012, 01:16 PM   #1 (permalink)
Tito is on a distinguished road
Default Cambelt timing marks
Hi,
I'm replacing a broken a cambelt on a Vitara JLX 1994, 16 valve. We aligned the "E" on the camshaft pulley with the "v"of the slot cut of the tappet cover, firing the front cylinder no.1 in the front and rocked cylinder no.4 at the back, gearbox side. It won't start.
Is no.1 on this engine meant to be in front (near the fan) or at the back (near the gearbox). If so, which marks on the camshaft gear must I use on the "v" slot on the tappet cover?
Does anyone have a diagram of this?
Tito is offline   Reply With Quote Quick reply to this message
Old 12-10-2012, 01:28 PM   #2 (permalink)
aquanaut20's Avatar
Engine/valve timing is set with #4 (rear) at TDC (c) compression...
Ignition is set with #1 TDC(c) (front cylinder)....
Caution, the 16V engine is an interference unit, do not use starter to rotate until you are sure you are mechanically timed correctly.... damaged valves will be the result....
.....Philip
92 Ford Explorer, 450k
97 Ford Explorer, 400k
Old 12-11-2012, 03:28 AM   #3 (permalink)
Thanks, Phillip,
I gave it a try and it's almost starting but it just won't catch.
The are a lot of markings on the cam pulley, which one's should i use?
Any ideas?
Old 12-11-2012, 04:01 AM   #4 (permalink)
Section Moderator
The cam uses the E marks, not 'I' marks which may be on your pulley. Crank key is at 12:00, cam key is at 6:00, timed to cylinder #4 compression stroke. Ignition is to cylinder #1. Car fires 1,3,4,2. The distributor rotates anti clockwise. Using the base clamp as 12:00, wire for cylinder#1 should be set at the 1:00 position.
'61 NSU Quickly - 150mpg
Old 12-11-2012, 09:40 AM   #5 (permalink)
xxx
my acid test in on my sneak a peek page.
it will not fail you.
How to Sneak a peek?
nor the tbelt page for 16v.
shows every pulley ever made,
and all false marks and keys.
NO "I" key
NO "I " marks.
the acid acid test, is normal compression
#1 has nothing at all to do with setting the cam.
the Tbelt came with instructions, mine states, #4 clearly.
if the marks are aligned, #4 is firing.. you nor anyone can change that.
its just where it is ,when aligned.
Old 12-11-2012, 09:43 AM   #6 (permalink)
xxx
it aligns to #4 rear. firing.
see acid test here. acid never lies.
NO "I" marks or keys allowed !
my tbelt page shows this.
hows this for clear on my 16v page.
