Bad master cylinder??? - Suzuki Forums: Suzuki Forum Site
Ľ Wheel & Tire Center
Old 12-04-2012, 05:27 PM   #1 (permalink)
make-tracks's Avatar
make-tracks is on a distinguished road
Default Bad master cylinder???
Iím experiencing s strange problem with my brakes. I suspect the master cylinder is leaking internally, however Iíd like outside opinions before replacing anything. Here are the specks 1997 Geo Tracker 4 door, 4x4, 1.6L 16 valve, 4 speed auto.
The breaks do not hold pressure not even when pumped. If I pump them I can raise the pressure just enough to shift it from park. I am not lousing brake fluid and the fluid level in the reservoir stays constant. So now for the odd partÖ. Whenever I pump the breaks while itís running, it drops my RPMís significantly, almost to the point of stalling. Is it possible itís a vacuum problem rather than my master cylinder, or is the master cylinder drawing so much vacuum that itís causing the low idle???
make-tracks is offline   Reply With Quote Quick reply to this message
Old 12-04-2012, 05:45 PM   #2 (permalink)
If, when you say the brakes are not holding pressure, you mean the pedal does not stop going down, then there is a leak - if the fluid level in the reservoir is not dropping, then the leak is internal to the master cylinder.
Old 12-05-2012, 07:39 AM   #3 (permalink)
xxx
starting when. ?
the story, it was all pefect , daily driving when....
or
found the car in a barn , parked for 10 years... bla bla....
if it dont leak, on the ground or under drivers feet (look behind mc, see a leak?)
then it's a bad MC
or is full of air (bleed it)
easy huh?
Old 12-05-2012, 11:23 AM   #4 (permalink)
Section Moderator
Perhaps check the brake booster and vacuum line going to it for leaks, as well as bleeding the brakes. Big vacuum hose goes to brake booster....
'61 NSU Quickly - 150mpg
Old 12-05-2012, 02:14 PM   #5 (permalink)
xxx
the brake work with zero vacuum.
and with a hard pedal. his is not hard.
Old 12-05-2012, 02:47 PM   #6 (permalink)
Section Moderator
He is also talking about braking affecting his idle, no?
Old 12-05-2012, 03:57 PM   #7 (permalink)
aquanaut20's Avatar
It may if he pumps the pedal, drawing vacuum down..... Philip
92 Ford Explorer, 450k
97 Ford Explorer, 400k
Old 12-06-2012, 06:55 AM   #8 (permalink)
xxx
the stroke decreases but not the hard pedal at the end
test it off road. remove and block the vacuum line.
or off road. cut the ignition and while coasting test the brakes.
the brakes must work with no vacuum, or the car is a death trap.
it drops my RPM’s significantly, almost to the point of stalling
both, if the diaphram cracks, it can cause a hot motor to go lean (this leaks is an illegal leak and makes EFI go lean, and rpm drop ,but on a cold engine , faster idle)
block the diaphram and retest. or do the diaphram leak down test. (pass ./fail)
there is a check valve at the entrance tot he brake booster, that most be good too.. it holds a vacuum in the chamber , so if the engine dies
you get 1 or 2 hits with ASSISTED brakes.
id not drive any car with those symptoms. the rpm must not drop. explain all symptoms, good and bad, with engine and brakes for better answers.
see my whos on first text file below.
Old 12-07-2012, 04:47 PM   #9 (permalink)
xxx
see how the booster works
see how the rod passes thru the whole MC system?
always fix the mechanical parts first then the booster last .
see the direct path in graphic 3 here.
brake overhaul
do not drive a car that , won't hold a hard pedal. or is spongy or pulling brakes.
there are 3 class leakage paths, 2 external and 1 internal.
the 2 external leak from lines or MC or slaves, in plane view, see em leak?
the MC can leak inside, and has bad seals. inside. with no external signs
if the external is leak free, and bled.
then the falling non hard pedal, is a bad MC.
Old 12-08-2012, 05:56 PM   #10 (permalink)
The breaks do work to some degree just very poorly (Not safe to drive). when I pump the peddle when it's cold it causes it to increase in RPM's. when the engine is up to temp it causes it to drop RPM's almost to the point of stalling. the break is soft, goes all the way to the floor, it's very soft until I pump it. after I pump it i have break pressure for 1 to 2 seconds.
