Transmission leak - Suzuki Forums: Suzuki Forum Site
Old 11-15-2012, 07:29 AM   #1 (permalink)
stutrac is on a distinguished road
Default Transmission leak
the leak is on the right side of housing looks to be near speedo cable input (only leaks over night) fluid not over full
1992 Geo Tracker LSI, 4x4, auto,A/C orig 89k miles
1973 Ford Rancero
stutrac is offline   Reply With Quote Quick reply to this message
Old 11-15-2012, 10:56 AM   #2 (permalink)
xxx
that is the transfer case. right.?
it does have 2 seals. an even the cable can leak.
only cleaning it and care checks can find this truth
Old 11-15-2012, 11:01 AM   #3 (permalink)
no transmission,ok maybe looks like a cable i could be wrong,the leak is on top of the pan area looks to be near shift selector, i know old Fords have a O ring that leaks in the same area(shift selector)
1973 Ford Rancero
Old 11-15-2012, 08:11 PM   #4 (permalink)
just went to the garage and found a large puddle of trans fluid all around the pan now it is dripping on the front drive shaft what are the common seals that go on this trans? the Modulator valve is dry around it, the outher owner did replace the trans mount looks to leaking around knockdown cable possible O ring ? Is the kick down cable easy to remove or is this a trans shop repair?
1973 Ford Rancero
Old 11-16-2012, 08:57 AM   #5 (permalink)
xxx
sound like you need a shop.
to find that source of a leak.
there are many paths for it to leak.
TC, pan, TV dentent. shift rod., MOD. tail shaft. oil pump. etc.
Old 11-16-2012, 02:10 PM   #6 (permalink)
i found the kick down cable that is leaking and the rubber protecting is gone, leaking fluid
tail shaft dry
TC dry
module do not know it is wet there
side shaft do not know it is wet from the top
1973 Ford Rancero
Old 11-16-2012, 03:51 PM   #7 (permalink)
xxx
some have a case oring that is very hard to replace
there are more pages not show, shifter seals, and front end ...
off my 3L30 page
see 16, 21 and 27 , all can leak
also the 4wd transfer class, intersection case (hollow)
as a drain, at the bottom ,if it drips ATF then 14 is bad
if the drain drips, GL4 (not pink, ) the the xfr case seal is bad.
Old 11-16-2012, 04:05 PM   #8 (permalink)
i could see where the fluid is being pushed out it is super clean in that area i did find a cable at Rock auto,but how is there product compared to a dealer item?also i was on kick fix site where is the adjustment info on the site?
1973 Ford Rancero
Old 11-16-2012, 04:51 PM   #9 (permalink)
xxx
tv cable
set it with some slack, its not critical , only that it NEVER causes
the throttle to jam open.
it is, here
The Kick down cable can rust ( free play is 0.039 inches,).
i try not to cover most adjustments that are i the fSM
the 1996 ackfaq covers both trannys.
its here.
Ack's FAQ Tracker Factory Service Manual Automatic and Manual Transmission On Vehicle Service
7a1 index and see page 7A20 TV adjustment
PDF page 22
.039"
Old 11-16-2012, 05:07 PM   #10 (permalink)
ok, i did a search function here and it said put trans in neutral and the cable should be installed with out dropping pan,and also i have to remove crossmenber and drop the trans to access the cable any outer easy way
1973 Ford Rancero
