struts - Suzuki Forums: Suzuki Forum Site
Old 11-08-2012, 11:09 PM   #1 (permalink)
blaze10 is on a distinguished road
Default struts
Looking into buying a lift will I need longer struts or no any info will help thanks
blaze10 is offline   Reply With Quote Quick reply to this message
Old 11-09-2012, 12:25 AM   #2 (permalink)
Kuhsoy is on a distinguished road
Most common lifts are spacer suspension lifts that are 1-2 inches, for these you will not need longer struts, at least to my knowledge
Info on your lift would help
1998 Chevy Tracker 16v 1.6L 5spd 2dr 3 pc. Hardtop 2"body 2"suspension 31x10.5x15 Nixen M/t 6000lb winch
1994 Geo Tracker 16v 1.6L 3 spd auto Soft-top Stock.
1991 Geo Tracker 8v 3spd auto Soft-top Stock
1989 Geo Tracker 8v 3pd auto 1 pc. Hard top Stock
Kuhsoy is offline   Reply With Quote Quick reply to this message
Old 11-09-2012, 12:42 AM   #3 (permalink)
Well I was looking at buying from a guy on here selling his lift which is ome coils spacers shocks an rear control arm drop down bracket. An he said I needed struts for the lift. This tracker is not my daily driver I got it to drive to work on occasion but mostly for the mountain to play in
Old 11-09-2012, 05:52 AM   #4 (permalink)
Go with what the vendor tells you, he should know what he's selling.
Having said that - I would strongly suggest you do your research before purchasing.
OME coils by themselves will lift the vehicle, and OME sells them with a longer struts & shocks, designed to complement one another. Adding spacers to the OME springs will lift the vehicle more - this increased lift may be the reason the vendor recommends longer struts.
Too much lift can cause problems - damaged CV joints is one of them, excessive camber and tire wear is a second. Ask the vendor what he recommends for these issues.
Old 11-09-2012, 08:45 AM   #5 (permalink)
The Goat's Avatar
The Goat is on a distinguished road
I'd strongly recommend making sure you do NOT get OME heavy springs and making sure you get the lightweight ones. The OME struts in the front are worth the money to me... much beefier than the elcheapo Napa specials. I'd also recommend the OME rears over the DoestchTechs. They are valved for the lighter suzuki.
As for using a strut drop spacer in the front... I'd do it. Struts don't like being topped out, and lift springs with a 1inch spacer will occasionally do so. Someone on here sells em, wild child maybe? Cool design.
Be aware, my strut mount failed at 2-3k miles post lift with 165k on the vehicle. 10$ fix at junkyard, I think 50$ new.
Bilstein struts are another option, but they are no longer than stock.
If you aren't going 30 inches+ I'd skip the spacers, buy new OME springs and buy bilsteins instead of ome struts. I'd keep their rears as they are longer . Still need arm spacer for the rear though.
Don't put toooooooooo heavy of a spring... think oldschool go kart.
1995 4DR Sidekick 16v w/4spd Auto J-Vin 205k
1996 4DR Tracker 16v w/4spd Auto Canada Vin 135k
"I'd rather drive a jeep, than deal with xtreme zuks offroad." -Jeremy Clarkson
The Goat is offline   Reply With Quote Quick reply to this message
Old 11-09-2012, 08:50 AM   #6 (permalink)
Idk which springs they are I just know that they are ome springs. I'll pay for the ome struts then . I was told to make sure I get she rear control arm drop kit.. no idea what that does though
Old 11-09-2012, 10:34 AM   #7 (permalink)
tshawgreatlakes is on a distinguished road
When you lift the rear by puting longer springs on it, the rear mount that sits above the rear end is on a angle causing stress where it mounts to the rear housing. It kinda looks like a ball joint. The spacer alows the rear mount to set flat like it was before the lift reducing stress as the veh flexes going over bumps ect ect. I think Low Range off roads web site has a list of OME struts that fit your veh. I have had real good luck with OME struts and shocks I have pounded them pretty hard for over two year with no problems TShaw
tshawgreatlakes is offline   Reply With Quote Quick reply to this message
Old 11-09-2012, 11:45 AM   #8 (permalink)
The Goat's Avatar
Lowrange has always treated me right. When another fender tried to gouge me on price and claimed to have the only lift left in the US of the kind I want... and had it priced 25% above retail, I made a call to lowrangeoffroad and they had multiple sets in stock and cut me a deal. Free t-shirts were a bonus.
When I needed a body lift immediately, they hooked it up and had it to me the very next day.
The only thing they did wrong was not talk me out of the OME heavy weight springs... and that was my fault.
Can't stress enough how easy they were to deal with.
As for how much lift you can do safely... the general consensus seems to be 2.5 without new a arms and a diff drop bracket. I've got 3.5...easily. I've had zero drive train issues but we have no rocks and I know when and where to add throttle.
If you're in hills, too big of a tire is going to murder acceleration.
Old 11-09-2012, 01:00 PM   #9 (permalink)
Well I want 2 1/2 inches of lift maybe a two inch body later on with 235 75 15 or maybe 245s ..
Old 11-09-2012, 01:01 PM   #10 (permalink)
Oh an thanks for the information I'm just young an new to this. I have a lifted Dakota with 35@ its a lot different then lifting a geo lol
