Manual Transmission drain and fill plugs - Suzuki Forums: Suzuki Forum Site
Old 10-01-2012, 12:11 PM   #1 (permalink)
John Mitchell is on a distinguished road
Angry Manual Transmission drain and fill plugs
Hey all. Went to change the gear oil in my 92 2wd 5sp Tracker and lo and behold..The oil fill plug is buggered to the point of being impossible to get out using conventional tools. Luckily I had checked the fill plug BEFORE draining he gearbox... So, I called my local Chevy dealer's parts dept to see of they had or could get me a new drain and fill plug and was told they were discontinued from them.. So..what to do? Are these plugs a common size I ought to able to get aftermarket at a parts house?
Thanks for any ideas or info you might have
Regards
John
John Mitchell is offline   Reply With Quote Quick reply to this message
Old 10-01-2012, 12:17 PM   #2 (permalink)
dustwatts is on a distinguished road
Regards
John
I think they are just pipe plugs..,,, take your fill plug and match it up, pretty sure drain is same size... and i think "pro's chime in if i am wrong" the front/rear dif use same size plug..
1994 Geo Tracker, 2dr, 5sp Manual, 4x4, 1 inch coil/strut spacers w/ 235/75r15
a/c system install
http://s832.photobucket.com/albums/z...ing%20install/
dustwatts is offline   Reply With Quote Quick reply to this message
Old 10-01-2012, 12:30 PM   #3 (permalink)
The plugs should be available from SouthWest Suzuki Motors - p/n 09246-16010 - around $5 each. The reason they get that way is people use a 3/8" square ratchet handle on them rather the correct 10mm square drive wrench.
dustwatts - the diff drains are the same, the fill are different.
Old 10-01-2012, 12:40 PM   #4 (permalink)
aquanaut20's Avatar
If removing is the issue, insert a standard bolt into the 10mm recess(hex head out) and weld it solid. Then use a socket to remove and reinstall.... Philip
92 Ford Explorer, 450k
97 Ford Explorer, 400k
Old 10-01-2012, 03:59 PM   #5 (permalink)
Thanks guys for the timely answers!
Old 10-01-2012, 07:26 PM   #6 (permalink)
nightw50 is on a distinguished road
What Aquanaut20 said.
95 Trkr Tintop Vin-6 16V 4wd 5sp A/hubs AC PS 235-15 Az pinstripes
nightw50 is offline   Reply With Quote Quick reply to this message
Old 10-02-2012, 01:06 PM   #7 (permalink)
deeznutts77's Avatar
Gallery: 4
i brought mine to fastenal and got stainless bolts n put them in.
96 jx 5 speed 1.6 16v "cold" air and try y header, underdrive crank, kawasaki zx6 muzzy muffler, gm alt kit.
96 "sport" 3spd auto 1.6 16v 2dr geo tracker all stock
It might not b fast but it looks it!!!!
deeznutts77 is offline   Reply With Quote Quick reply to this message
Old 10-02-2012, 11:06 PM   #8 (permalink)
trackerER is on a distinguished road
I bought replacements from NAPA. They sell square head ones. Not recess square like allen head but sticking out. I think they are made of brass.
1998 Chevy Tracker, 1.6L, 16v, MPI, manual tranny, 4x4, 2dr, soft top.
trackerER is offline   Reply With Quote Quick reply to this message
Old 10-03-2012, 07:28 AM   #9 (permalink)
ranger88den's Avatar
I think Permatex makes a thread sealant with properties to prevent corrosion between dissimilar metals.
Old 05-22-2013, 03:40 PM   #10 (permalink)
ORF-Tracker's Avatar
ORF-Tracker is on a distinguished road
Garage
Yeah so here's the difference between all these work arounds; the OEM p/n 09246-16010 is now made of steel, has a magnet, and has the green thread protector. My original plugs are made of aluminum and are junk. Looks like they upgraded these since 1991. I got the last 2 from oemsuzukiparts.com p/n 09246-16010 is also used on the swift and old suzuki outboard motors.
US Federal '91 Geo Tracker Softtop 1.6 8v 2DR 4X4 3 spd auto CAMI RWAL A/C 162,000 miles
US Federal '93 Geo Tracker Softtop 1.6 8v 2DR 4X4 3 spd auto CAMI RWAL A/C 88,000 miles
2007 Jeep Commander Limited V8 Hemi 4WD 88,000 miles
ORF-Tracker is offline   Reply With Quote Quick reply to this message
