95 geo tracker - Page 3 - Suzuki Forums: Suzuki Forum Site
Old 11-08-2012, 02:42 PM   #21 (permalink)
Section Moderator
McProy, the hardware for the top changed in 1995, so you have to make sure that you only order a top that is good for 1995-1998. For years 1994 and earlier, the top will not fit your car, and you will need to change the front bow on the car, as well. 1994 and earlier do not have zip out side windows. Anyway, aside from places like Bestop, etc., you can often find them for sale on ebay, as well.
'61 NSU Quickly - 150mpg
Old 11-10-2012, 09:11 PM   #22 (permalink)
1992_Tracker is on a distinguished road
I just bought a 92 tracker and the brakes on mine r doing the same thing urs are. Did you figure out a fix yet or diagnose the problem at least. I'm gonna try a fluid flush first maybe ill get lucky. Please post up if u find a cure.
1992_Tracker is offline   Reply With Quote Quick reply to this message
Old 11-11-2012, 05:09 AM   #23 (permalink)
Section Moderator
1992Tracker, you should really start your own post regarding your own particular symptoms - brake pedal goes to the floor? Do you have braking? Normally, the brake pedal being soft/going to the floor is an indication of a hydraulic fluid leak in the brake system, or air. Is the master cylinder brake fluid level good? Do you have to add brake fluid? Probably the first step would be to check the brake lines for leaks, make sure fluid is good and topped up, or bleed the system to remove any air in it, then refill and see if the brake problem continues.
Old 11-11-2012, 08:40 AM   #24 (permalink)
GumbyCT is on a distinguished road
Can't say if this is your problem (cuz I haven't heard your symptoms) but I know I have found bleeder valves that were seeping because they were NOT tightened by the last person to bleed the brakes.
The only symptom was a loss of fluid with no known leaks, well until you look at the bleeder valves and see the wetness.
96 Geo Metro 84 k mi 3cyl 5sp Lsi
01 Chevy Tracker 4D, 2.5L auto trans, A/C, ps, 125k, mi. auto locking hubs
Under Repair
95 Tracker 2D Conv. 16v VIN#6 171k mi. 5sp A/C ps
96 Sidekick Sport 4D 1.8L, auto AC 114k mi.
GumbyCT is offline   Reply With Quote Quick reply to this message
Old 11-11-2012, 09:26 AM   #25 (permalink)
My symptoms were the same as urs when the brake pedal is first applied they go almost to the floor before working but if I pump the pedal once or twice I have a very firm pedal and the brakes work pewrfectly
Old 11-11-2012, 09:38 AM   #26 (permalink)
Section Moderator
You need to advise what diagnostic tests you have done - checked for leaks, level of brake fluid, bleeding, etc. We cannot see the car from here!!
Old 11-11-2012, 09:48 AM   #27 (permalink)
This isn't my thread so I wasn't asking for anyones help or opinions other than the op, on what he did to fix his brake issue. Because he said his brakes went to the floor unless he pumped the pedal. So for u to get on n be a douche to me because I have 2 posts is ridiculous. I can see already this forum isn't much different then any other a select few get off on a power trip hiding behind their keyboard. This is just a beater for me my other vehicle is a 2003 cummins n I've done more wrenching then most my age id say so anyway just forget I was ever here because I certainly won't be back. Ill figure my problem out on my own. Sorry for the derale to the op.
Old 11-12-2012, 04:59 AM   #28 (permalink)
Section Moderator
A bit testy. AFAIK, this thread was not necessarily about brakes. In any event, if you want help, post on the forum. I'm done.
