Aerio - Sidekick swap - Page 4 - Suzuki Forums: Suzuki Forum Site
Old 10-18-2012, 08:40 PM   #31 (permalink)
rmadness's Avatar
rmadness is on a distinguished road
I did the conversion, you will need 4 door rotors, brake pads, calipers and caliper mounting brackets. The rear you just transfer over all hardware, drums, backing plates, well at least on 96-98. If you have 95 and older and use 96/98 parts you would need axles from 96>.
94/96 Chev/Geo Tracker junkyard dog 8v 5spd p/s 4x4 conversion 2dr conv w/hardtop 2000 tracker wheels/emblems 2004 tracker seats, spare tire cover, 4 door tracker brake conversion, stereo Oldsmobile Aurora cd/cassette w/jvc speakers USA CAMI, ZOR winch bumper with modified land rover brush guard, warn 10000lb winch, ZOR rear bumper, 105 amp CS130 GM alternator conversion.
rmadness is offline   Reply With Quote Quick reply to this message
Old 10-18-2012, 09:02 PM   #32 (permalink)
littlebigman is on a distinguished road
Garage
So basically I am looking for a pre 95 brake set front and rear. Sweet! Now to just find a junk 4dr to pull everything off of....Well at least the backing plate and caliper/caliper mounting bracket. I'd buy everything else new.
rmadness:
Did you notice a night and day difference? Or just a little?
Also how is your brake master cylinder holding up? I am guessing it is the same for the 4dr but just trying to cover all my bases
93 Sidekick 2DR 4x4 5speed 1.6L 8V
Homebrew intake
Thrush turbo muffler-sounds sick!
Bored out cat 7/8"
15x7 83 ford mag alloy's coated black
Red LED interior lights
2-4" wide rectangle off road lights
Front and rear bumper cover's gone
To come:
1" spacers under front springs
235x75R15 Hercules Trail Grabber's
KYB struts/shocks
Lowrange RV cam
Lowrange headers
LSD rear end
littlebigman is offline   Reply With Quote Quick reply to this message
Old 10-18-2012, 10:55 PM   #33 (permalink)
rmadness's Avatar
I did notice a dramatic decrease in stopping distance and much better pedal feel overall. I have a winch bumper w/ winch (not shown in pic) which added about 175 lbs, so my results may be somewhat different than yours but the conversion was definately worth it and junkyard parts for me were a steal around $100.00 for everything. I used a new 4 door master cylinder.
Old 10-19-2012, 04:38 AM   #34 (permalink)
Guest
Why would you need to change the axles?
Old 10-19-2012, 09:22 AM   #35 (permalink)
rmadness's Avatar
The axles on most 95 and earlier 2 doors used an axle where the brake drum used four nut/studs to hold the brake drum onto the axle, the five lug studs were still attached to the drum. On 96-98 it was changed to one where the drum slides over the lug studs that are pressed into the axle flange, and is held on by a "press fit" requiring a puller to remove it. Most of the four door I've seen use the later style.
Old 10-19-2012, 09:50 AM   #36 (permalink)
Guest
I guess thats a 16V/8V difference, all the 8Vs that we got through to 2001 have the 'old' style mounting so I didn't have that issue.
On mine I had a 'Y' connection from the main brake line that linked the two rear drums together, because only one of the LWB calipers had a bleed nipple I had to make up new rear lines. Mine was never fitted with an LSPV either.
