1500 RPM on cold start - Suzuki Forums: Suzuki Forum Site
Old 03-30-2012, 06:59 PM   #1 (permalink)
stallone is on a distinguished road
Default 1500 RPM on cold start
hi suzuki gurus. just want to ask if it is normal to have 1500 RPM during cold start for about 3 minutes before going down to "800 or 1000" RPM? Will this 3 minute high rpm cause premature wear and tear on my engine? Newly cleaned IAC/ISC for my 98 sidekick G16B, 1.6, 16V, Philippines. Thanks in advance.
My Ride: 4 door Suzuki Vitara 98, Philippines, 16V,MPI G16B engine , 4 speed AT
stallone is offline   Reply With Quote Quick reply to this message
Old 03-30-2012, 09:19 PM   #2 (permalink)
loosenut is on a distinguished road
My trackers all do this. I doubt that any amount of additional wear would result from this. It will sound kinda buzzy but all good.
loosenut is offline   Reply With Quote Quick reply to this message
Old 03-31-2012, 02:45 AM   #3 (permalink)
rootuser is on a distinguished road
Mine has been doing this forever. Seems to be fine. Once it warms to operating temperature the idle drops, pretty standard for mine.
1993 Suzuki Sidekick JX 1.6L 8-valve, 4WD, 5-Speed, 2dr, factory hard top
Almost completely stock. 180,000+ miles original motor, original clutch. ~28MPG.
rootuser is offline   Reply With Quote Quick reply to this message
Old 03-31-2012, 05:41 AM   #4 (permalink)
Section Moderator
They all do this. Extra air is pumped into the engine at cold start up (which will raise the idle as the computer pumps in extra fuel), so that the car warms up faster. This is normal.
'61 NSU Quickly - 150mpg
Old 03-31-2012, 06:22 AM   #5 (permalink)
thank you very much for the responses. : )
Old 03-31-2012, 10:02 AM   #6 (permalink)
Peculiar1's Avatar
Gallery: 3
Peculiar1 is on a distinguished road
Welcome to the forum stalone.
Consider yourself lucky your's is working properly.
I gave up on getting mine to do as it should. Now as suggested by Bex before somewhere on here I just manually keep the RPM's up til I get going
A ISC runs around $220 I think.... and I'm just not ready to spend that yet for what is just a nuisance issue so far.
I just pulled 29.8 mpg from the last tank, all town driving. So all is good other wise.
1994 Suzuki Sidekick 2dr 1.6, SOHC, 8valve, 4x4, Auto hubs, Manual trans, Mfg Cami
92 Honda LX Wagon
84 Toyota Corolla
03 Suzuki DRZ 400s
75 Ford LT 125 12hp Tractor/w plow.
74 Yamaha DT 360A (New project)( Now a put off project)
94 Geo Tracker 8v,hardtop,4x4. (parts car)
78 YZ 250 (racing vintage class this year '17)
73 DT3 250 Enduro. (Rode it all last summer)
Peculiar1 is offline   Reply With Quote Quick reply to this message
Old 03-31-2012, 01:11 PM   #7 (permalink)
Section Moderator
Peculiar (and sorry for bit of hijack) but if this is happening to your car only during cold start up, and your warm idle is fine, then chances are this is the idle air valve on the throttle body that may be blocked up. You can carefully try cleaning it (and the port you see when the valve is pushed in). We have also learned that this idle air valve can be regulated somewhat by turning the metal ring on the front of the valve (inside the cover). Search the forum, as this was posted within the past month or so. I believe to raise the idle, you would turn this CCW. You would need to have the car off while doing this, turn the ring 1/4 turn CCW, then start the car and see if/how your cold idle is affected, and adjust accordingly.
Old 03-31-2012, 05:48 PM   #8 (permalink)
PARKRAT is on a distinguished road
I just finished adjusting mine, about 1/2 turn ccw will raise your cold idle about 500.
89 GMC Tracker SLE 2 DR TIN TOP A/T 4X4 A/C 245000 KMS, FOR SALE.... 2001 SILVERADO LS LT LT 111,000 KMS, NOT FOR SALE.
PARKRAT is offline   Reply With Quote Quick reply to this message
Old 03-31-2012, 06:53 PM   #9 (permalink)
thanks Peculiar1. Despite your ISC problem, you still get 29.8 mpg. I'm not getting beyond 12mpg for my sidekick.
Old 04-01-2012, 07:52 AM   #10 (permalink)
Section Moderator
12mpg??? Sounds like you are in limphome mode. Is your check engine light on with the key on and then off once the car starts? It must be.
Have you done any maintenance on the car? (timing/tune-up etc).
Your car should be getting at least 25mpg or so. Answer about the check engine light (or advise if it is on all the time). Basically, the computer puts the car into limphome when it is unable to read the signals from the various sensors - the computer then goes to a pre-defined set of values just to 'get you home'. Your car must be running horribly!!! Give more info.
(And thanks, Parkrat - your advice means then to reduce the IAC input, you must turn the ring clockwise....)
