EGR Modulator - Suzuki Forums: Suzuki Forum Site
Old 12-22-2011, 08:56 AM   #1 (permalink)
Peculiar1's Avatar
Gallery: 3
Peculiar1 is on a distinguished road
Default EGR Modulator
Evidently the sticker came off my modulator. I didn't realize there is a P and Q for vacuum hose connections. Is there a way to tell? If one pulls the little cover off the top and removes the filter, there is a little hole in the plastic.
Sitting in the vehicle is that hole orientated toward the throttle body or the right fender? If someone knows how to tell or would kindly do a hands on looksie, I would appreciate it.
One more question. Do all Sidekicks fall under "Federal" emissions.? I am using a 93 fsm (tracker) and it talks of resetting the maintenance whatever that causes the check engine light to come on and stay on.
I attempted to read flashes last night to fix the code it threw....no flashy, just stared at me without blinking.
1994 Suzuki Sidekick 2dr 1.6, SOHC, 8valve, 4x4, Auto hubs, Manual trans, Mfg Cami
92 Honda LX Wagon
84 Toyota Corolla
03 Suzuki DRZ 400s
75 Ford LT 125 12hp Tractor/w plow.
74 Yamaha DT 360A (New project)( Now a put off project)
94 Geo Tracker 8v,hardtop,4x4. (parts car)
78 YZ 250 (racing vintage class this year '17)
73 DT3 250 Enduro. (Rode it all last summer)
Peculiar1 is offline   Reply With Quote Quick reply to this message
Old 12-22-2011, 11:16 AM   #2 (permalink)
BOZO's Avatar
Gallery: 3
BOZO is on a distinguished road
The reset for the SES is located behind the left front speaker. It's a little toggle switch. Just switch it to the opposite position that it's in now and you should be good to go for a few years.
- 1995 Geo Tracker 2dr, Soft Top, 5sp, 4x4 w/manual hubs, A/C, PS, 160,000mi.+ VIN2CNBJ1866S693XXXX
{{{FRANKENKICK}}} Eng. VIN G16T10XXXX (1996) 1.6L, 16v, MFI, ECU PN:70EA0, SES removed at cluster,
4 Firestone Winterforce 205/75-15 tires on stock aluminum rims
- 1999 Chevy Tracker 4 dr, 2.0L, 5 speed, 4x4
***Please disregard the 'Expert' label as it appears under my user name. Thank you.***
BOZO is offline   Reply With Quote Quick reply to this message
Old 12-22-2011, 11:54 AM   #3 (permalink)
Section Moderator
Are you talking about the little hole that is in one of the nozzles as you are looking inside the modulator?? If so, that is the P side and goes toward the throttle body.
The service engine soon switch can be in a number of places - some behind the left speaker - mine is behind a little door under the steering wheel - its just a sliding switch, if you find it, just slide it to the other side. Normally you can tell if its the nag that is on, as it goes on at an even mileage.
'61 NSU Quickly - 150mpg
Old 12-22-2011, 12:39 PM   #4 (permalink)
Peculiar1's Avatar
Gallery: 3
Hi Bex, on mine with the filter removed, the tiny hole does not line up with either vacuum hose connection. It is off set.
_ hole
P/Q ??______________P/Q?? ( top view filter removed)
This is how mine looks looking down Again my orientation will be from the driver seat
Thanks.
(nipple(s) are where the vacuum hose(s) connect. on the outer side of modulator. If this crude drawing doesn't help I'll take a pic.
92 Honda LX Wagon
84 Toyota Corolla
03 Suzuki DRZ 400s
Old 12-22-2011, 12:53 PM   #5 (permalink)
Section Moderator
If you look from the outside, does the side of yours, under where the nozzles would be, have a vent hole? If so, that vent hole should be under the Q nozzle and point toward the EGR valve (the one with the diaphragm)
Old 12-22-2011, 01:29 PM   #6 (permalink)
Peculiar1's Avatar
Gallery: 3
[IMG][/IMG]
92 Honda LX Wagon
84 Toyota Corolla
03 Suzuki DRZ 400s
Old 12-22-2011, 01:52 PM   #7 (permalink)
Section Moderator
See the little hump on one of the nozzles? That's Q. And that goes toward the EGR valve.
Old 12-22-2011, 02:06 PM   #8 (permalink)
Peculiar1's Avatar
Gallery: 3
Thanks Bex. Sorry for the confusion. Oh remember that plunger I was talking about in the EGR valve...that does move...when under acceleration (reving up under hood.)
Now if the reset switch works and the check engine light goes out.
I will be ready to time it with a timing lite.
I had a no start after T/B job...I was off 1 or 2 teeth. Didn't pay attention when tensioning belt.. Do and learn..lol! But for christs sake 11 o-clock rotor position seems a some what VAGUE....imo.
If FSM had said rotor facing # 1 on cap would have saved me some time.
Thanks again.
Have a good x-mas.
92 Honda LX Wagon
84 Toyota Corolla
03 Suzuki DRZ 400s
Old 12-22-2011, 02:15 PM   #9 (permalink)
Section Moderator
Pah. Should have searched forum and found this:
