clutch knocking - Suzuki Forums: Suzuki Forum Site
Old 08-23-2011, 02:58 AM   #1 (permalink)
stocko is on a distinguished road
Default clutch knocking
the clutch in my 95 vitara knocks as i engage and disengage it while the car is running, does not do it turned off. just hoping to hear some thoughts about it..
stocko is offline   Reply With Quote Quick reply to this message
Old 08-23-2011, 04:31 AM   #2 (permalink)
Section Moderator
The clutch on the Vitara is a mechanical clutch that does not rely on ignition.. It might be an idea to try to locate exactly where the knocking noise is coming from, like have someone engage/disengage the pedal while someone else is under the car (with mechanic's stethoscope, rubber hose, or possibly just your ear), and listen (and also look at the clutch cable action). Have you ever changed the clutch cable? They have a life of about 100,000 miles, and can put great pressure on the firewall, etc., if they start to bind. Some clutch info here:
My clutch is sick what is wrong
Does your car go into gear properly? Tranny slipping at all, etc.?
'61 NSU Quickly - 150mpg
Old 08-23-2011, 02:00 PM   #3 (permalink)
bog
Banned
knocks
first ever
check squacks. here
you must clearly say exactly what is knocking or the cloud people here, run and hide.
after all ,we cant here it,
Old 08-23-2011, 02:02 PM   #4 (permalink)
bog
Banned
while runnng ,
parked
in neutral
you press the clutch pedal, just taking up all slack in the cable do you hear
noise, just as you that.
you are not depressing pedal to floor.
read chapter 0C
Ack's FAQ 1996 Geo Tracker Factory Service Manual
Old 08-23-2011, 02:20 PM   #5 (permalink)
greentruckhank is on a distinguished road
Ive heared of throwout bearings knocking but that was back in my high school days on 55 fords. I don't think they do that nowadays. Squeal maybe. Be aware were dealing with my memory here-------Hank
greentruckhank is offline   Reply With Quote Quick reply to this message
Old 08-23-2011, 04:58 PM   #6 (permalink)
bog
Banned
you do know, that any clutch made, can break in infinite ways (but in the T/T plate, plate to housing and pivets, diaphragm spring breakage or rivet failures, or a progression of all) then there are cascade fails.
right. ?
even the simple throw out can collapse and warp and make any amount of noise it wants. sure. as you say, google failure mechanisms manual clutch.
t
even the bolts can be loose. on the pressure plate itself or the lever holding the PP casting (pivot) levers (to outer housing) can fall off and bang, knock.
if you want ill send you one or more for play. (we have a dead clutch room in the shop with hundreds of bad clutches)
or the pilot shaft tip failure and/ or bearing allowing the pilot to wobble clutch disengaged and yes knock.
the front tranny bearing can knock in neutral\
but no,
knock on wood
Old 08-23-2011, 07:15 PM   #7 (permalink)
the knock is coming from the transmission, and i'm pretty sure the clutch cable is the original, i was told i'd have to pull out the gearbox?
Old 08-23-2011, 07:41 PM   #8 (permalink)
bog
Banned
sure sounds like clutch and box.
with clutch pedal depressed, if sound stops it's the clutch and not transmission.
(rare case of jammed clutch and box expected)
my test for burned up throw out is easy , light foot pressure.
sorry for loss.
Old 08-23-2011, 09:19 PM   #9 (permalink)
so i should pull it apart replace the clutch and the clutch cable and she should be right??
Old 08-24-2011, 07:46 AM   #10 (permalink)
bog
Banned
95 5sp, knocker.
i cant hear it, but if the noise can be heard inside tranny or clutch bell housing
the problem is inside.
i think your mech, must have heard it, right?, and said it was in the tranny/clutch.
a stethoscope will help here.
the noise happens parked. right?
and happen in neutral with foot on the clutch or off the clutch pedal, right?
and i presume it makes noise moving down the road.?
and your sure this not the engine.?
only careful listening with a stethoscope to engine then bell then tranny can tell you what is actually making that noise. (im in the cloud and cant hear it)
