Side gear swap on front differential - Suzuki Forums: Suzuki Forum Site
Old 04-24-2011, 09:04 PM   #1 (permalink)
zuki_uki's Avatar
zuki_uki is on a distinguished road
Default Side gear swap on front differential
Can someone clarify how this is done? I've got the front differential sitting on my workbench and curious about this sidegear swap for my 96 sidekick. I've got a set of 5.63 gears. Do I need to pull the ring and pinion apart?
Is there some instructions that I can find somewhere?
Thanks,
96 Suzuki Sidekick LX 2dr 1.6L 16v 4x4 5spd CAMI
06 Chevy 2500HD Duramax 4x4
66 Chevy Caprice Big Block
04 Toyota Camry
zuki_uki is offline   Reply With Quote Quick reply to this message
Old 04-24-2011, 10:16 PM   #2 (permalink)
loosenut is on a distinguished road
I hope you got the carriers with those gears. If thats the case its plug and play, nearly anyway. Your gear set may be specific to the carrier. I know the dana 30 from cherokees cant just swap out, you must have the proper carrier. I pulled my traks rears (both trackers) all apart to spool them up with little trouble. I had to do a pattern and retorque but no real problems
loosenut is offline   Reply With Quote Quick reply to this message
Old 04-25-2011, 09:02 AM   #3 (permalink)
zuki_uki's Avatar
I've got the complete carrier with ring and pinion in the complete 3rd member. I haven't taken down my original 5.12 gears yet to see if there is a difference, but from what I understand, the side gears must be changed out.
I've checked my repair manual to see if there were instructions, but no luck in the Haynes manual. I'll first either count the splines or see if my CV joints will fit, if not, then I know I'll need to do the swap.
Someone has to know what I have to tear down to change these things.
04 Toyota Camry
Old 04-25-2011, 09:04 AM   #4 (permalink)
Banned
autotune is on a distinguished road
sure we have the FSM lited in sticky post #1 with 5 stars no less
here it is
try 4c
Ack's FAQ 1996 Geo Tracker Factory Service Manual
no secrets
autotune is offline   Reply With Quote Quick reply to this message
