Geo Tracker axle swap - Suzuki Forums: Suzuki Forum Site
Old 02-17-2011, 07:34 AM   #1 (permalink)
howierd is on a distinguished road
Default Geo Tracker axle swap
I have a '97 Geo Tracker 2 wd with 5 spd manual transmission. Rear axle ratio is 5.12:1. I just exchanged rear axles and installed one with a 4.3:1 ratio. The speedometer now reads approximately 10 mph slow. What's available to correct it?
howierd
howierd is offline   Reply With Quote Quick reply to this message
Old 02-17-2011, 07:56 AM   #2 (permalink)
FireCkrEd is on a distinguished road
Howie,
I just stick my GPS on the window and it gives perfect MPH.
Ed
FireCkrEd is offline   Reply With Quote Quick reply to this message
Old 02-17-2011, 08:15 AM   #3 (permalink)
BOZO's Avatar
Gallery: 3
BOZO is on a distinguished road
I think the speedometer gear is in the transfer case, but I don't know if it's as simple as changing it out with one from a 4.30:1 vehicle.
Glancing at the FSM, it looks like the speedometer drive gear is removable from the rear output shaft. I don't know which is necessary, the speedometer driven gear on the end of the speedometer cable or the speedometer drive gear on the main shaft. Sorry.
What kind of performance/driveability are you noticing with the lower gears? Do you like it?
- 1995 Geo Tracker 2dr, Soft Top, 5sp, 4x4 w/manual hubs, A/C, PS, 160,000mi.+ VIN2CNBJ1866S693XXXX
{{{FRANKENKICK}}} Eng. VIN G16T10XXXX (1996) 1.6L, 16v, MFI, ECU PN:70EA0, SES removed at cluster,
4 Firestone Winterforce 205/75-15 tires on stock aluminum rims
- 1999 Chevy Tracker 4 dr, 2.0L, 5 speed, 4x4
***Please disregard the 'Expert' label as it appears under my user name. Thank you.***
BOZO is offline   Reply With Quote Quick reply to this message
Old 02-17-2011, 09:51 AM   #4 (permalink)
BOZO's Avatar
Gallery: 3
Doh!, just realized you have a 2wd.
Looks to be the same deal only on the mainshaft of the transmission near the output end.
Old 02-17-2011, 05:00 PM   #5 (permalink)
Default Tracker axle swap from 5.125 to 4.30 ratio.
Thanks, Guys:
I have been using my GPS and it works well. 45mph=55, 50=60; 55=67; 60=72. I can now cruise on the highway at 3000 rpm and be traveling at 68 mph. As for fuel economy, the first tank went from 30mpg to 36 mpg. Performance is good.
Old 02-17-2011, 05:45 PM   #6 (permalink)
Good news, I like it. Now, with an Ecotec might be a bit higher too.
Other Toys...
2016 Chevrolet Colorado LT 3.6 V6 G80 Locker
2009 Pontiac G8 GT 6.0L
2007 VWL Beetle 5 Cly
2003 Chevrolet Impala 3.4L
2001 Pontiac Grand Am SE 3.4L
Tracker Photos
Richard Craneum is offline   Reply With Quote Quick reply to this message
Old 02-17-2011, 06:44 PM   #7 (permalink)
BOZO's Avatar
Gallery: 3
Good to hear. How'd you calculate your fuel mileage when the speedo/odometer are off? Can you accumulate mileage on your GPS?
If you didn't compensate for this, then couldn't your MPG be even higher?
Just wondering.
Old 02-17-2011, 08:40 PM   #8 (permalink)
I think is done by distance travel via Map and time of travel.
Used a Magellan before and I must say that was pretty accurate compared to my car speedometer.
Other Toys...
Tracker Photos
Old 02-18-2011, 05:05 PM   #9 (permalink)
The Magellan GPS allows you to accumulate trip mileage as well as use it for a speedometer. It seems to be very accurate. First report was on 1/2 tank of gas. Going to run the entire tank out this time before calculating mileage. One hundred miles on the odometer translates to 121 on the GPS.
Howierd
Old 02-18-2011, 05:15 PM   #10 (permalink)
I think the Speed is calculated on segments by a sample distance between Point A and Point B divided by an internal clock time (lets say, .001 Sec to .005) and repeats all over again. I believe the GPS system has an Universal Clock that syncs all Satellites and GPS Receivers.
The distance travel is different since is based on a road map Vs an actual road reading (both could not be accurate adding a larger degree of inaccuracy) from Point A origination and Point B final destination.
Well, that is my take on it
Other Toys...
Tracker Photos
