1997 Tracker, 4 Wheel Drive, manual hubs, 2H, 4H, 4L - Suzuki Forums: Suzuki Forum Site
Old 04-20-2010, 11:12 PM   #1 (permalink)
SmallTimer is on a distinguished road
Default 1997 Tracker, 4 Wheel Drive, manual hubs, 2H, 4H, 4L
This 1997 Tracker is my first 4wd vehicle.
Manual locking front hubs (at front wheels)
2H- I understand this is normal 2wd, provided the front hubs are not locked.
Q1- Is it OK if the front hubs are left locked while in 2H operation for long periods?
Q2- If the front hubs are locked while in 2H. The front wheels are meshed together, and will not turn independant of each other, making it harder to turn, correct?
4H-
Q3- does anything bad happen if the vehicle is driven in 4H for long periods, if the front hubs are not locked?
Q4- I suppose this simply spins the transfer case for no good reason?
Q5- does this lock the rear wheels together?
Q6- 4L & 4H are identical, except for lower gearing, right?
1997 Geo Tracker Lsi, 4 door hardtop, 1.6L - 16 valve, U.S.
Engine being rebuilt, new crank, new pistons, the crank pulley bolt broke and the crank pulley waddled out the crank end.
Got the Factory Manual on the way.
SmallTimer is offline   Reply With Quote Quick reply to this message
Old 04-21-2010, 06:38 AM   #2 (permalink)
mongoosevrx's Avatar
Gallery: 13
mongoosevrx is on a distinguished road
I would unlock the front hubs when you're not going to use 4wd. I is so easy to unlock them.
The differential is made to allow one wheel to turn faster than the other, so you will only notice, at least I do, some more vibration, and lower gas mileage.
DO NOT engage the 4wd without locking the front hubs
You cannot do anything to the rear wheels("lock them together") without adding a spool or locker or lsd or welding the spider gears. The only thing you should do with it is change out the gear oil(in all three boxes)
'93 tracker two door
4x4 manual hubs, 5-speed
1.6l 8v 131,000 miles?
2" coil lift
2.5" body lift
2" wheel spacers with 30x9.5 tires
mongoosevrx is offline   Reply With Quote Quick reply to this message
Old 04-21-2010, 10:14 AM   #3 (permalink)
Cool, thanks
Old 04-21-2010, 10:32 AM   #4 (permalink)
BOZO's Avatar
Gallery: 3
BOZO is on a distinguished road
And never use 4wd without low traction conditions. The drivetrain will bind and break. It's been said that even wet pavement is not loose enough for 4wd operation.
There's a great section on 4wd operation in the glove box operator's manual. If you need one, read the sticky on service manuals and there's a number there where you can get one for free. Oh, it's a Tracker. There should be a link in that sticky where you can download the OpMan from GM for free.
- 1995 Geo Tracker 2dr, Soft Top, 5sp, 4x4 w/manual hubs, A/C, PS, 160,000mi.+ VIN2CNBJ1866S693XXXX
{{{FRANKENKICK}}} Eng. VIN G16T10XXXX (1996) 1.6L, 16v, MFI, ECU PN:70EA0, SES removed at cluster,
4 Firestone Winterforce 205/75-15 tires on stock aluminum rims
- 1999 Chevy Tracker 4 dr, 2.0L, 5 speed, 4x4
***Please disregard the 'Expert' label as it appears under my user name. Thank you.***
BOZO is offline   Reply With Quote Quick reply to this message
Old 04-21-2010, 10:37 AM   #5 (permalink)
Banned
wet and dry pavement is same.
wind up
see TSB on your car on how to UNWIND your car.
free.
Old 04-21-2010, 03:11 PM   #6 (permalink)
Section Moderator
Sorry, what is TSB?
And to poster: the operating manual actually advises you to lock your hubs about once a month,(no need to put transfer case in 4wd) in order to keep the hubs lubed properly. Turning is a slight issue here, as the front wheels are turning at the same rate, even though they are going a different distance in the turn. Our cars do not have a locking rear differential, so the rear wheels are not locked.
'61 NSU Quickly - 150mpg
Old 04-22-2010, 12:27 AM   #7 (permalink)
BOZO's Avatar
Gallery: 3
TSB = Technical Service Bulletin
Old 04-22-2010, 07:46 AM   #8 (permalink)
Thanks Guys!
Great Advice. I've done the advised reading, and it was very informative. I've never had a 4wd before, and I didn't realize such information.
Thanks again!
Old 04-22-2010, 08:14 AM   #9 (permalink)
Banned
wind up
Driveline bind, binding hubs, axle wind up, axle bind, drive line wind up - all terms for one thing: stress due to part time 4 wheel drive
TSB suz
for the unfortunate.
the actual TSB, on how to undo it.
http://kick-fix.com/tranny/xfr-case/...up/ts327aw.jpg
Old 04-22-2010, 08:16 AM   #10 (permalink)
Banned
do a wiki read on
part time 4 wheel drive.
not AWD at all.
