dtc P0121 TPS circuit malf. - Suzuki Forums: Suzuki Forum Site
Old 01-11-2010, 03:44 PM   #1 (permalink)
Suzukinoob is on a distinguished road
Default dtc P0121 TPS circuit malf.
got a 2002 Vitara 2.0 L , and have dtc p0121 TPS circuit malf.
i disconnect the maf sensor and it runs fine, with the maf connected it blows black smoke, doesn't idle, runs rough.
If i connect the MAF it dies.
is there any way to test the maf?
or is this a common thing?
BTW there is a dtc for a bad maf altho it isn't coming up on my scanner
Suzukinoob is offline   Reply With Quote Quick reply to this message
Old 01-12-2010, 07:57 AM   #2 (permalink)
Section Moderator
Unfortunately, on the 'side of the wall' we only deal with the cars from 89-98. As yours is 2002, you should post on the other side with the newer cars. That being said, our wonderful kick-fix pages does have a section for testing the MAF:
Howto-test-a-MAF
Again, this is for the older cars, and I don't know if its applicable to your car.
'61 NSU Quickly - 150mpg
Old 01-12-2010, 02:45 PM   #3 (permalink)
Banned
your post is confusing. mixing maf 2 times.
TP Circuit Performance Problem
TPS malf.
if you unplug any sensor the ecu goes to limphome and mimic mode.
it will run rich but will run. after all better to have transportation than a brick.
the ECU does compare MAF out put to TPS and load.
and can in fact report the wrong one.
your problem is a cake walk, connect scantool and just look.
nothing more need be done.
certainly spending $1000 guessing.
scan it.
Old 01-12-2010, 02:49 PM   #4 (permalink)
Banned
depending on whats wrong ,unplugging something can make it run better.
eg: if MAF is reading low all the time (AFR is lean) "wrong" and you unplug it.
sure richer from super lean is better.
but not right.
plug in the scan tool see what MAF , o2 and TPS are really doing.
this can also be totally unrelated.
gross air leaks, slipped timing belt or chain as approp.
just because TPS monitor malf's , i can be lots of things.
on all obb2 cars, you need to look at pending codes too. never ever forget that.
check compression and vacuum on all cars malfing,to besure motor is viable.
no ecu can operated a dead motor. none. (well, not correctly and proper)
