Door hinges - Suzuki Forums: Suzuki Forum Site
Old 12-07-2009, 07:30 AM   #1 (permalink)
06vmaximus is on a distinguished road
Default Door hinges
Anyone have a solution to bad driver and passenger door hinges? I would like to replace with new, but cannot find any. Help! (96 geo tracker 2 door soft top 16 valve 4x4 automatic 168,000 miles)
96 tracker 16v auto 4x4 fed 168,000 miles
06vmaximus is offline   Reply With Quote Quick reply to this message
Old 12-07-2009, 07:50 AM   #2 (permalink)
Shoot these people an email OEM Suzuki Parts
Just ask for sidekick hinges...cheaper than using Tracker parts.
B95
Bear95 is online now   Reply With Quote Quick reply to this message
Old 12-07-2009, 04:06 PM   #3 (permalink)
riley's Avatar
riley is on a distinguished road
I bought mine from these guys Carjunky.com carjunky - Auto Parts and Accessories Catalog - Door Hinge - Suzuki Sidekick Door Hinge
I ordered a set for the drivers door and they were around $25 delivered to Nova Scotia Canada. Took about a week to arrive, I bought the cheap ones that were 5 or 6 bucks each. You can buy hinge pin replacement kits with new bushings and pins at most auto parts stores. Some people use old valve out of engines to replace the pins. good luck
1990 Sidekick, 8V, 1.6L, 5 speed, rag top
1996 X90 auto....
1993 Geo Tracker 5 speed
riley is offline   Reply With Quote Quick reply to this message
Old 12-07-2009, 04:50 PM   #4 (permalink)
Good find! I have never had a problem with my hinges but I have friends with older ones that have.
B95
Old 12-07-2009, 04:51 PM   #5 (permalink)
You guys are great! Thanks.
Old 12-09-2009, 01:08 PM   #6 (permalink)
garcia is on a distinguished road
Maybe hinges can be repaired?
A machinist can even insert brass bushings so they last even more?
garcia is offline   Reply With Quote Quick reply to this message
Old 12-09-2009, 07:29 PM   #7 (permalink)
Yes its true that anything can be repaired with enough time-effort-money, but it is really cheaper to just replace them with new ones at $18.00 each. The problem was that I was unable (until now) to find new ones. I am going to take a look at how bad they really are this weekend when I remove them. I know the drivers side is bad, because the door rubs the lower skirt when I open it!
Old 08-09-2010, 07:52 PM   #8 (permalink)
EXFFPM is on a distinguished road
Default '94 Geo Tracker drivers side top hinge bolts pulled out of frame post.
I had noticed that the area around the door "limiter" strap in the frame between the hinges had been brazed/welded and is cracked as well. I opened the door and the top bolts pulled out of the metal. Any suggestions? What do I need to remove to access the back side of the bolts to attempt a repair?
Geo has a "service bulletin" #731067, NHTSA# 54197 regarding "upper door hinge loosens from body"?
EXFFPM is offline   Reply With Quote Quick reply to this message
Old 08-11-2010, 08:21 AM   #9 (permalink)
R_Zachs's Avatar
R_Zachs is on a distinguished road
rock auto in seattle. google them
2005 Dodge Ram 3500 QCLB 6spd
1991 Chev S10 Reg Cab Short bed Iron Duke 5sp
1989 Geo Tracker 2dr 4wd 8v 5spd with ProTops
R_Zachs is offline   Reply With Quote Quick reply to this message
