Engine Noise - Suzuki Forums: Suzuki Forum Site
Old 12-06-2009, 11:22 AM   #1 (permalink)
clifsmith is on a distinguished road
Default Engine Noise
I finally got her running. The engine seems to run ok. New oil pump works fine after shaving off a little metal to allow clearance for the timing gear. I bought this car without hearing the engine. It had a crank keyway problem that cause the timing gear loosen and grind into the oil pump. I jbwelded the new key in and put loctite 660 on the crank surface the timing gear goes on. I ran it yesterday and the engine sounds like a diesel. That is the best way to desribe the sound. I does it at idle when cold, but goes away when warm. When warm, Under heavy accelleration is goes away, under decelleration it comes back loud as heck. At first, I was thinking "rod bearing play", but not sure, maybe valve train. It is a substantial and loud sound and does not sound good at all. Any ideas?
clifsmith is offline   Reply With Quote Quick reply to this message
Old 12-06-2009, 12:05 PM   #2 (permalink)
Sævar Örn's Avatar
Sævar Örn is on a distinguished road
Check valve lash clearance first of all.
1997 Suzuki Sidekick G16B 33" mod - 208 kms
1997 Suzuki Vitara G16B - 33" mod - 178k kms
1995 Suzuki Sidekick G16B - 30" - 142k kms
Owner and webmaster of Icelandic Suzuki 4x4 club site http://sukka.is
Sævar Örn is offline   Reply With Quote Quick reply to this message
Old 12-06-2009, 05:49 PM   #3 (permalink)
will that make a diesel like loud racket? I did check my timing, it was 25 degrees BTDC, I adjusted it to 5. That made some difference, but the problem still exists.
Old 12-07-2009, 07:17 AM   #4 (permalink)
Section Moderator
You should post exactly what kind of car you are running, 8v/16v, year, 4wd? etc. Put it into your signature so people know what you're talking about without having to search around.
'61 NSU Quickly - 150mpg
Old 12-07-2009, 08:07 AM   #5 (permalink)
1997 Geo Tracker, 2wd, 5spd, 16v
Old 12-07-2009, 09:04 AM   #6 (permalink)
Section Moderator
Your timing was off, how did it ever get to 25* BTDC??...here is good post showing how to exactly set for your car. 16v.
How to set ignition timing
and for valve lash:
http://www.kick-fix.com/t-belt/LASH/Lash16v.html
Old 12-07-2009, 10:07 AM   #7 (permalink)
I replaced the timing belt cog and timing belt. I was very careful to have the crank and cam sprocket marks aligned when I put the belt on. I got it on the money. I am not sure why the timing was so far off. Anyway I have it to 5 degrees, but my issue still persists (see above). I did check the lash on about 4 different valves just to see and they were all right at .008", which I believe was in spec, so I did not bother wiht the rest, not to say that there is a problem. I think setting lash would be worth a try, but that sound is so loud and diesel like, I would be surprised if the valve lash really is the culprit, but it might. I was just trying to see what it could be based on the symptoms I have described above.
1997 Geo Tracker - convertible, 5spd, 2wd, 1.6, 16v. 147k miles
Old 12-07-2009, 11:56 AM   #8 (permalink)
randy h's Avatar
randy h is on a distinguished road
Garage
I would suspect either valve lash out of adjustment or valve damage resulting from the original keyway problem. If it were my car, i would check valvelash per kickfix's pages, then a compression check. The compression check would most likely give you an indication of whether you have valve damage. Bad compression = bent valves (most likely from keyway damage) but other possible causes too.
Check and set your lash, then do a compression check and report back your findings.
randy
95 Geo Tracker, USA FED, 16 valve, 4X4 - MNL Hubs, 5 spd Manual, Pwr Steering, AC, 2 Dr,
Aftmkt:Removable Hard Top, Pwr Windows-Locks-Cruise, 90 Amp Alt.
randy h is offline   Reply With Quote Quick reply to this message
Old 12-07-2009, 12:55 PM   #9 (permalink)
good idea randy. What should I expect in PSI for compression test? 140k miles.
Old 12-07-2009, 02:20 PM   #10 (permalink)
randy h's Avatar
Garage
170 on all four, taken with all plugs out and Fuel Pump Relay defeated, is a nice reading.
For more thorough information on Compression testing and Valve Lash setting, check KickFix pages: The KickFix Repair Pages, for Sidekicks and Trackers
randy
