1997 sidekick Sport hydraulic clutch mech - Suzuki Forums: Suzuki Forum Site
Old 07-01-2009, 06:28 AM   #1 (permalink)
tirebiter is on a distinguished road
Default 1997 sidekick Sport hydraulic clutch mech
No hydraulic leaks at master or slave cylinder. (1997 sidekick Sport 1.8 engine). Clutch master cylinder half full and dry all around. Dry at slave cylinder also.
It took about two weeks to go from barely noticed to no clutch disengagement whatsoever. Shifter moves freely into all gears with engine shut off. Lot's of grinding wen trying ti shift when engine is running and clutch pedal fully depressed.
Is there a normal wear point or bushing that could wear out enough to cause the clutch to drag ? Doesn't the clutch normally start to slip when it is due for a release mechanism adjustment ?
Tirebiter
1997 4WD Sidekick Sport 1.8 L
tirebiter is offline   Reply With Quote Quick reply to this message
Old 06-05-2010, 04:17 PM   #2 (permalink)
joebama is on a distinguished road
Unhappy i need help
i'm loooking for a 1.8 engine for my suzuki sidekick around the miami area can anyone help me find one please.
joebama is offline   Reply With Quote Quick reply to this message
Old 06-05-2010, 04:37 PM   #3 (permalink)
Section Moderator
You need to start your own thread. The title of this one has nothing to do with your request and is misleading.
'61 NSU Quickly - 150mpg
Old 06-05-2010, 10:45 PM   #4 (permalink)
Banned
ok ,dont try to recover every drop of fluid
imagine 1 drop every 100 miles.
and after time it gets low.
this is so very very common fail.
ive gone thru 2 slaves on my mx5 in 2 years.
(driving the heckoutofit)
what id do,is ,just replace the dirt cheap slave.
Price a new clutch job.
like the easiest job on the car.
replace it and bleed it. if all is well ,so be it.
if not,the MC.
usually the mc will leak on drivers side fire wall. with lots of proof.
but not slave they are a trick bunch.
did you look under the slave boot, see lots of fluid, well there it is.
and dead wrong to be there.
new slave time.
can even kit it super dirt cheap too.
if you can see its main drive rod while someone else presses pedal ,you will see it is
deads ville.
Old 07-21-2010, 03:11 PM   #5 (permalink)
scoots is on a distinguished road
Check the bracket that connects the clutch pedal assembly to the master cylinder plunger rod.
I had a problem just like this on my '97 sport jlx. Actually, it happened twice.
It started off with a little resistance getting into gear and got progressively worse.
I checked fluids/leaks and found nothing. I replaced slave then master cylinders and got no change. I then took it to a clutch shop and they (big surprise) told me I needed a new clutch and quoted me almost $800.
I didn't believe them and kept digging. I finally crawled under the drivers side dash and took a look at the pedal assembly and noticed a small tear in the metal bracket connecting the pedal assembly to the master cylinder.
The bracket had bent a little and was not pushing the rod in far enough to release the clutch. Replaced the bracket and everything was working great again!
scoots is offline   Reply With Quote Quick reply to this message
Old 05-12-2014, 09:09 PM   #6 (permalink)
tirebiter123 is on a distinguished road
Where did you get another bracket?
tirebiter123 is offline   Reply With Quote Quick reply to this message
Old 05-12-2014, 10:19 PM   #7 (permalink)
Kodiak's Avatar
Kodiak is on a distinguished road
Holy thread revival Batman!
97 Sidekick Sport 4x4
155hp 2.3 Aerio powered
Spartan locker
RRO 4 1/2" lift
RRO sliders
ZOR winch bumper
Smittybilt XRC8
245/75/16 Duratracs
Kodiak is offline   Reply With Quote Quick reply to this message
