EGR Hell - Page 2 - Suzuki Forums: Suzuki Forum Site
Old 03-20-2017, 03:46 PM   #11 (permalink)
ranger88den's Avatar
Javier, when I go to your profile you only list your vehicle as a '94. What make is your vehicle? What is your location? Have you checked the rest of the exhaust system for restriction, eg catcon?
Old 03-20-2017, 04:52 PM   #12 (permalink)
lifesawrench's Avatar
lifesawrench is on a distinguished road
Sorry for the missing info, Ill update it, but here it is real quick: Hard Top Sidekick 94, Cammy (made in Canada for US market) located in Puerto rico. No I have not checked the rest of the exhaust. What should I be looking for? I believe my Catcon is still good. How to troubleshoot it if in doubt?
Cheers!!
Hard Top Sidekick 94, CAMI made
16V 1.6L 4 Door
4 Speed A/T
lifesawrench is offline   Reply With Quote Quick reply to this message
Old 03-20-2017, 07:08 PM   #13 (permalink)
Section Moderator
Just to give you a bit of guidance, a code 51 is thrown for one of two reasons, either:
The engine coolant is less than 140F but exhaust gas is greater than 428F, or the engine coolant is equal or greater than 158F and the intake air temp is equal or greater than 122F. You advised that you don't have a vacuum pump - perhaps you should check to see if the diaphragm will actually move if vacuum is applied to it??
'61 NSU Quickly - 150mpg
Old 03-21-2017, 12:26 AM   #14 (permalink)
Thanks Bex. Well if volts and ohms are accurate, then ECT is reading right coolant temp, right? Or can there be a margin of error? Hot engine ect ohms are 271 and volts .64v.
About the air temp how can I validate/check that? Does Rad flow has to do with this?
If temp is reaching 180 (which looks like it) could the T-stat be defective anyways? I still have not troubleshoot that yet, but its only about 2 years old. I have the 195F one.
16V 1.6L 4 Door
4 Speed A/T
Old 03-21-2017, 06:27 AM   #15 (permalink)
Section Moderator
The computer is getting temps off of various systems. Your ECT may be giving the correct ohms, but the little temperature probe in the EGR valve may not be giving the correct voltage. It's the thermoprobe in the EGR that communicates with the ECU, for the EGR circuit/code 51.
Old 03-21-2017, 06:58 AM   #16 (permalink)
Yes I forgot. The Thermoprobe ohms are as low as 12.6 when put on boiling water, but only 34.5 when I opened EGR main to let exhaust in (of course car shuts off). I dont know the volts that the thermoprobe should have cold/hot or at any temp.
16V 1.6L 4 Door
4 Speed A/T
Old 03-21-2017, 09:16 AM   #17 (permalink)
Section Moderator
The factory spec ohms across the connector, on the sensor side of the harness, are usually taken when the engine is fully warmed up. The boiling water test is somewhat meaningless, as you need to backprobe while attached to the circuit. When the engine is cold, the spec is about 40k ohms, and when warmed up, its about 10k. You can also check the voltage for the thermoprobe itself, by disconnecting the connector, having the key on, and checking for voltage on the ECU side of the connector. You should have about 5v. If less, then it's time to start looking at wiring.....By the way, if you are pushing the valve forward, and your engine is stumbling or shutting down, it usually indicates that the passages are clear enough.
Old 03-21-2017, 11:34 AM   #18 (permalink)
Well, if measured on car letting it get hot by moving egr main by hand the lowest it went was 34.7k ohms(I can retests to be sure). My boiling water test was to make sure it went below that number and it did, 12.6K. Cause if even when put in hot boiling water if it stayed the same, then it could indicate a no good thermoprobe or not necessarily?. Cold mine is not 40k, it is between 200-300k range. Will have to check volts, which I still have not. And yes my guess is not blocked passages, as IM was cleaned right before engine rebuild (december) and about 2 weeks ago again.
Thanks!!
16V 1.6L 4 Door
4 Speed A/T
Old 03-22-2017, 06:07 AM   #19 (permalink)
Section Moderator
My point was that when you put the thermoprobe in boiling water, you are taking it out of the circuit that you wish to test.....if you just have the car at warm running temp, and it's idling, what is the reading (without touching the diaphragm)??
Old 03-22-2017, 07:07 AM   #20 (permalink)
Yes it was reading but I dont remember the omhs. Let me retest.
Good day!!
16V 1.6L 4 Door
4 Speed A/T
