1995 kick clutch cable advise - Page 2 - Suzuki Forums: Suzuki Forum Site
Old 02-17-2017, 08:16 AM   #11 (permalink)
Section Moderator
Can you upload a photo of what you're seeing?? I can't find a photo in the forum, other than the diagram that's in the FSM - note that this has the two locknuts further down the cable, rather than the round rubber stopper that you have:
http://www.suzuki-forums.com/suzuki-...h-bracket.html
And here, this uses the locknut set up, but you can see the end of the cable/threaded rod, etc. Here:
'61 NSU Quickly - 150mpg
Old 02-17-2017, 12:21 PM   #12 (permalink)
Mobie1's Avatar
Mobie1 is on a distinguished road
okay I will try to get photo posted THANKS
Mobie1 is offline   Reply With Quote Quick reply to this message
Old 02-17-2017, 05:22 PM   #13 (permalink)
Mobie1's Avatar
I guess I need an image hosting site.
But I can tell you a little more.
I measured the exposed wire cable Before depressing- It was over 2 inches
When clutch it depressed it looks around 1.5 inches.
Its hard for me to tell.. I'm Old and not to nimble
I have a pic ,,maybe I will see about image hosting. Guess I will risk a drive to shop soon
Old 02-18-2017, 05:24 AM   #14 (permalink)
Section Moderator
You don't need image hosting. When you are on the reply page, scroll down halfway and you will see 'manage attachments'. Click on that, and another window opens, allowing you to search through your computer for the photo that you want to upload, and then upload it into your reply. It will come in as a thumbnail at the bottom of your post, and when people click on that thumbnail, it will open as a larger photo.
Old 02-18-2017, 01:40 PM   #15 (permalink)
Mobie1's Avatar
okay Hard to crawl under this is the best I got
the cable before depressing is around 2 1/2 inches and its over 1 inch depressed.
Sorry I was unable to focus on attachment rubber stopper
Old 02-19-2017, 05:02 AM   #16 (permalink)
Section Moderator
Hmmm....I suppose I should crawl under mine, and see what my cable looks like - I don't really remember. But what concerns me more is the 'stiffness' that you advise. The cable exerts a tremendous amount of pressure - enough to crack your firewall, if its the wrong cable or not routed correctly. And aftermarket cables are confusing - they come in different lengths, can be measured differently, etc. Your clutch pedal, if all is correct, should not be stiff, but smooth and easy to depress. Normally a stiff pedal indicates a worn, incorrect or poorly routed cable. As your original cable is already binned, it's impossible to compare the lengths of them. Hopefully someone else will chime in about the visual at the end of their cable, before I have to crawl under mine....
Old 02-19-2017, 11:38 AM   #17 (permalink)
Mobie1's Avatar
Okay. Thanks
The mech..said maybe something wrong in the clutch.. causing cables to fray/
Old 02-20-2017, 04:54 AM   #18 (permalink)
Section Moderator
Frankly, I think that your mechanic is putting in an incorrect, aftermarket clutch cable into your vehicle. While it will be more expensive (but less expensive than changing the cable every 6 months), I suggest that you purchase a Suzuki OEM cable for your vehicle. I would also take a look at the firewall, where the cable comes through it, and look for cracking, etc. And, frankly, probably get another mechanic, as well....
Old 02-20-2017, 11:45 AM   #19 (permalink)
Mobie1's Avatar
okay..
I will try and find OEM''
Suzuki is gone .
also GM cables might work.
Hope someone can post Part# for GM or Suzuki cable
1995 sidekick JS 2 wheel drive 4 door
Thanks again
Firewall looks Okay..
I see no straining or movement when depressing clutch pedal
Old 02-20-2017, 11:50 AM   #20 (permalink)
Originally Posted by Mobie1 View Post
okay..
Suzuki is gone .
Thanks again
I provided that information in post #7. Click the link scroll down to the list. OEM parts vendors are even listed and you can find OEM vendors (Suzuki & GM) using Google.
B95
1996 Track/Kick 4x4 5sp 16v 2dr removable hardtop.
Bear95 is offline   Reply With Quote Quick reply to this message
