Yesterday I changed my intake manifold on my 1993 sidekick 1.6L manual transmission 4x4. When I got everything put back together I started it and it was smoking alot but running fine. I turned it off to try to locate the issue. I started it again and it ran worse than before and still smoked. The next time I started it, it barely ran and now it won't start. Does anyone have any ideas what the problem could be
if anti-freeze gets in the cylinder it can make it into the oil. Besides not being a very good lubricant (like water) Antifreeze can chemically damage the bearings.
It sounds like you have a leak at the intake manifold, did you check the replacement for flatness? are you sure that you have the correct gasket?
Related Threads
Suzuki Forums
604.8K posts
126.3K members
Since 2004
