95 Tracker OBD1 test plug - Suzuki Forums: Suzuki Forum Site
Old 02-03-2007, 09:11 AM   #1 (permalink)
tim123 is on a distinguished road
Default 95 Tracker OBD1 test plug
Hi, I'm new here. Thanks for the forum. I'm trying to check my codes via instructions in Haynes manual. They show a 4 pin plug, I have a 6 pin plug. Don't want to mess anything up. Which pins should I short together? Thanks Tim
tim123 is offline   Reply With Quote Quick reply to this message
Old 02-03-2007, 10:49 AM   #2 (permalink)
Paulsonlaw's Avatar
Paulsonlaw is on a distinguished road
Thumbs up Here you go
Ok, so you have a six slot clip with 5 pins in it right?
So if it looks like this...
UP
l A l B l C l
l D l E l F l
Up is the notch. A is Blank. You want to "jump" B & D then turn the key to the on postion.
*** People say that if you slide the switch under the dash, back in and to the right of the driver side speaker, will reset the light.
I also found out that this switch left in the other position puts the com in a program mode and can cuase some problems and may not let you pull codes ltr.
Best way is to disconnect the batt or the comp fuse.
GL!
Paulsonlaw is offline   Reply With Quote Quick reply to this message
Old 02-03-2007, 04:58 PM   #3 (permalink)
Thanks, that really helped alot. Ended up resetting the switch by the left speaker and checking the code. All I got was 12, and the light has stayed out for several miles. I guess it was a scheduled maintenance code. Thanks a million
