Go Back   Suzuki Forums: Suzuki Forum Site
Suzuki Forums: Suzuki Forum Site (http://www.suzuki-forums.com/forum-index.php)
-   Suzuki Sidekick, Escudo, Vitara & Geo Tracker Forum (1989-1998) (http://www.suzuki-forums.com/suzuki-sidekick-escudo-vitara-geo-tracker/)
-   -   Cylinder Head Oil Passages (http://www.suzuki-forums.com/suzuki-sidekick-escudo-vitara-geo-tracker/92857-cylinder-head-oil-passages.html)
thebukweet 11-14-2013 10:08 PM
Hello there,
I'm a new guy trying to put my 1998 Suzuki Sidekick 1.8L 4X4 back together!!! It's been frustrating but fun.
I've never done this before, so please bear with me:)
I've had the cylinder head off and machined. I got it back on there and am now attempting to install the camshafts, however:
The first thing the Chilton says to do is to "Fill the oil passages of the cylinder head with clean oil by pouring oil through the oil holes. Ensure that the oil comes out from the oil holes in the sliding in the sliding part of the valve lash adjuster bores."
What are they talking about here? Is is the holes like these?:
http://i228.photobucket.com/albums/e...4at95304PM.png
Each valve lash adjuster bore has little holes in the side of them above the valve spring (16 in all), do I need to fill each one until full?
What about the holes on the front end of the cylinder head?
I hope this makes sense, please let me know if you all need any other information.
I really wanna get this right the first time!!!!
Thanks in advance:)
Max 11-15-2013 06:07 AM
Factory Service Manuals link for the 1.6 and 2.0 4 cyl (along with the 2.5 V-6)
Hope this helps.
My Files
fordem 11-15-2013 06:10 AM
Those are the holes - I believe if you squirt oil into the lower left hole in your picture it will eventually reach the others - the idea here is to make sure that the passages are not blocked.
I'm going to ask Max to send you a link to the factory service manual for the Grand Vitara - it includes a section on the J20A engine, the J20A is a long stroke version of your J18, take a look at that and see how Suzuki does it.
thebukweet 11-15-2013 11:05 AM
WOW. Where was this manual when I started this?!?!:)
Thank you!!!!
Gigafex 11-15-2013 11:21 AM
hey max would you happen to have the manual for a 95?
Max 11-15-2013 12:21 PM
fordem 11-15-2013 04:37 PM
Max - you are fast.
